Missing COM Port After Changing Mount
1 reply34 views
Mossyback avatar
Due to a mount failure I’ve had to change to a new mount. (CEM 70) In N.I.N.A. all of my equipment hooked up to the mount without problems except my ROR which uses an Arduino/RRCI for connection. With my previous mount COM 6 was always used. Now, for some reason it is not available and the COM’s offered don’t work. This negates the ability of N.I.N.A. to use Cloudwatcher/Solo to close roof in the event of rain.
I need to solve this problem or if it can’t be resolved get another system in place.
I tried to post on Discord but N.I.N.A. has been moved to GitHub and not being a computer person I found it impossible to navigate so I’m hoping for some help here.
Any suggestions or solutions would be appreciated.
Hank
Brian Puhl avatar
If the driver situation hasn’t changed, something is disconnected. Start swapping cables. USB cables fail often.
Why are you hooking things up to the mount? Bypass it and run it straight to PC, rule things out.
Concise
camera use conflict with two zwo cameras; one for imaging, one for guiding
Here is my issue: I use a zwo asi 2600 imaging camera via SGP and then have tried to use an AsI Zwo 220 mini for guiding via ascom on PHd2. The problem is the PHd2 software reads the pixel size not at 4 but at the size for the 2600 camera. This occur...
Mount connection issues differ; this is camera-specific pixel size problem.
Aug 31, 2024
Connecting a VIxen mount to NINA
I can't really decide whether this is a question for a Vixen area, an ASCOM query or best off here, so apologies if this is the wrong place but… …I'm trying to connect my Vixen SXP2 mount to my PC. Currently, I connect the Star Bo...
Missing COM port issue may relate to mount connection problems on PC.
Mar 27, 2025
