zwo 183mc pro using a nikon 14 to 24 mm lens
2 replies377 views
Rex Walker avatar
I am just getting started in Astro photography I am using  zwo 183mc pro using a nikon F2.8 14 to 24 mm lens to get as wide angle and as much color as I can.
I have read that the L-eXtreme filter only passes 10 percent of the H alpha below F5 . Should I be using RGB filters?  Anny suggestions please.
You shouldn't use any filter except maybe a LP one (such as L-PRO) at f/2.8.
Steven avatar
"as much colour as I can"
yea, that might not happen with an L-Extreme filter. Don't get me wrong. It's an incredible filter, but it is a very narrow filter, which will only allow Hydrogen and Oxygen through. So your images will contain those two elements, which will mainly be Red and Blue.
If you want more colour, the Optolong L-Pro might be better. it will give more natural colours to your image.
But I don't know if the L-Pro is any better at F2.8.
And, yes. From what I can find, is that the L-Extreme isn't great at low apertures. It's really made for F5 scopes.
I have no idea what filter would work well at this apertures.. maybe look at what filters people are using who own RASA telescopes (F2). Or consider stopping down to F4-5 on your lens.
Solar Imaging "Path Forward" Advice Needed....
I have been into wildlife photography for about 8 years and just got into astrophotography a few months ago. I have been lurking around here recently and just joined yesterday. I have enjoyed viewing everyone's images and seeing the equipment use...
New astrophotographer seeking advice; similar beginner experience and gear questions.
Oct 29, 2023
Rokinon 135 mm f2
I purchased a Rokinon 135 mm f2 earlier this year for use in wide field work with APSC and full frame cameras both digital and CMOS. I've tried numerous setups with this lens direct camera mounted, multiple different set ups with my ASI 2600 MC P...
Wide-field astrophotography lens discussion relevant to author's wide-angle approach.
Nov 13, 2023
First Astrophotography Setup
Hello fellow astrophotographers! I am excited to venture into the world of astrophotography and have been diligently researching and assembling my first setup. I have some prior experience with photography using a Nikon DSLR, but now I'm eager to...
First astrophotography setup discussion directly relevant to beginner equipment selection.
Jul 25, 2023
