Blue halos around stars after LRGB combining in PixInsight
7 replies160 views
Georg N. Nyman avatar
Hello all,
I took subs with LRGB filters with an APO - processed them equally in PI and after combining them as LRGB, many stars show this strange blue halo - which does not exist in the single mono channels - any idea how they came into existence and what to do to get rid of them?
Thanks for your feedback!
Georg
D. Jung avatar
Are you refocusing between the different filters? Focus is wavelength dependent and if you don't refocus, your different colors will be slightly out of focus depending on the quality of optics you have.
D. Jung · Oct 30, 2025, 10:12 AM
Well, just what is necessary to keep the subs well focused - with AF routine in NINA!
Do you think that those blue halos come from subs which had not beed perfectly refocused after filter change - that could be possible, however I am not aware of it. The subs look all pretty good and well focused?
D. Jung avatar
How does the hfr value look like for the different channels?
It's quite possible that you have best focus for all 3 filters, but the optics are not well enough corrected and you just end up with halos.
D. Jung · Oct 30, 2025, 10:30 AM
The optics is a 12” Truss RC and perfectly corrected
D. Jung avatar
I see, if you have no glass in the optical train at all, that explanation makes no sense. But looking at your screen shot, the star sizes seem to be visually different between the different channels.
D. Jung · Oct 30, 2025, 10:57 AM
That I realized just a minute ago as well - I forgot to make “linear fit”….. it resolved the problem totally - everything is OK again!
Thanks a lot for pointing that out!!
Georg
Brian Puhl avatar
Georg N. Nyman · Oct 30, 2025, 11:01 AM
Georg
I was just about t make this suggestion. Glad you figured it out.
QHY Minicam8 blue halo
Hello to all Minicam8 users. I experience a substantial halo when I use the blue filter, that result in a blue halo around the brightest stars. Anyone else have this issue? Do you have any suggestion on how to deal with it in post processing? Olivier
Blue halos around stars after LRGB combining in PixInsight — directly addresses blue halo issue.
Feb 20, 2026
Help With Strange Gradient
Hi all, I'm just making this post because I'm at a bit of a loss on how to process some data I've recently acquired. My university was kind enough to let me use one of their telescopes to take some images on. I decided to shoot M 83 becau...
Blue halos around stars after LRGB combining in PixInsight — image processing issue relevant to telescope data.
Jul 9, 2024
Fixing RGB channel shifts in long moon exposures?
On Nov 8th I had the most perfect night for a shot of the moon on its 17th day: Little wind from top to bottom atmosphere, thus seeing was excellent and my scope was finally well collimated. So I went for a long desired full moon disk shot in best qu...
Discusses channel alignment issues that could cause halos in LRGB processing.
Nov 13, 2025
[RCC] Galaxy post processing M101
Request you to provide your critique - It is my first attempt to post-process galaxy data. I obtained the data from TAIC workshop. The LRGB subs were already stacked and registered, even cropped to good extent. I proceeded with these steps, providing...
LRGB processing example that may show similar artifacts or solutions.
Aug 19, 2025
How to get rid of Alnitaks blodge?
I took this image of FlameNebula and Alnitak, but can't get rid of the incredible blodge around Alnitak, which stems from the filters used. Any idea how to get rid of this artefact in Pixinsight? Image was taken on an 11" EdgeHD with L-Enhan...
Blue halos around stars may relate to filter-induced artifacts in PixInsight processing.
Feb 29, 2024
