Filters on unmodified DSLR
6 replies114 views
Alex Lutes avatar
So, I'll get straight to the point. After much processing, I've come to the conclusion that I have a very limited area of ​​sky unaffected by city glow. Ironically, this is the southern sector of the sky, where, in my opinion, the DSOs are the most beginner-friendly. I'm starting to think about two- or three-band filters for my standard Canon 6D to at least increase contrast at the expense of increased integration time. Maybe someone can suggest a filter that would work for me, or maybe this whole idea is a bit silly?
bigCatAstro avatar
Alex Lutes · Oct 22, 2025 at 11:57 AM
Definitely not silly, but I don’t know if this is the best use of your money and time.
I also had this same dilemma to deal with a couple of years ago and I ultimately went with a budget cooled osc (SVBony SV405CC). I chose this for the ability to create dark(s) libraries and to further automate my capture process. Likewise, my unmodified Canon T5i just wasn’t up to the task.
Thomas avatar
So I’ve used the Astronomik Clip In filters back in the day. I had an unmodded Canon EOS 750D and was shooting from heavy light pollution in the Denver suburbs. The Ha and Oiii filters were definitely useful and I could see a big difference when using them. The CLS one worked well also but my biggest bang for buck was definitely the Ha clip in filter. Don’t expect anywhere near the results you would get using a cooled astro camera with narrowband filters but the clip in ones aren’t half bad either.
bigCatAstro avatar
Thomas · Oct 22, 2025 at 02:11 PM
Great points, especially regarding managing expectations with the results you’ll get with an unmodified DSLR versus a cooled astro-camera.
I will also elaborate on my prior post in saying if you are interested in mostly galaxies and star clusters, then a stock DSLR with clip in filters is fine. However, if you’re looking to capture emission nebulas, you’d be better off with moving to a dedicated astrophotography camera (cooled or astro modified DSLR). I speak from experience in that I struggled to reach what I wanted to do by trying force tools to work for purposes that they were not designed to do. I used to “image” with a stock Canon T5i and an old Celeston C8-N on a beat-up Celestron CG-5ST. I wasted a lot of time and effort trying to make that set-up work.
ScottF avatar
I used to use a canon 60D and experimented with NB clip in filters. It was not a good experience and I never got anything useful out of it. IMO, I would take the money you would spend on those filters and put it towards a mono camera and proper NB filters. The qhyccd minicam 8 is an economical way to get into a dedicated camera.
James Eaton avatar
I would recommend getting it astro-modified - I did for my Canon 70D and have used narrowband filters with great results. It wasn't expensive, especially compared with buying a cooled astro camera (although I now have one of those too thanks to eBay), and I found it really increased the quality of my images.
Well written Concise
Armin Lukas avatar
I started astrophotography with an unmodded DLSR. At the time I was not really satisfied with the results. The IR Filter takes almost all light above 600nm, which makes it difficuilt for astrophotography.
After getting a modded DSLR, the results were much better!
Before buying a light pollution filter, definitely consider getting a modded DSLR (which are quiet cheap nowadays) or a proper (cooled) astro cam.
The results will be much better, even without the light pollution filter.
New to or Considering Astrophotography/astronomy?
I had posted this with a new image I’d uploaded as a change from the “typical” review of my processing steps/acquisition. A friend/commentor suggested I post in a forum, so this is the result. This is VERY subjective and based entirely on my experien...
Author seeks filter recommendations for light pollution mitigation with Canon 6D camera.
Jul 31, 2025
