Jerry Gerber avatar
I’m using the 10Micron GM1000 mount with NINA. Nina’s logs are warning that the mount’s interval polling is slower than the default 2 seconds that NINA expects. Sometimes the mount takes over 6 seconds to report to NINA.
Should I change the polling interval to 10 seconds in NINA and forget about it or should I take the log’s warning seriously and contact 10Micron (I already did that but haven’t heard back in several days)?
Since the polling interval affects more than one device, I am not sure what to do here.
Thanks,
Jerry
Jerry Gerber avatar
AstroStew · Oct 19, 2025, 09:42 AM
Jerry Gerber · Oct 19, 2025 at 02:55 AM
Thanks,
Jerry
Yes change the setting as 2 seconds is far to low for any of the 10 micron mounts, that maybe fine for much less accurate mounts, change to 10 and forget
On a 10Micron mount, the polling interval is not a fixed, user-adjustable setting in the way it is on other mounts
Instead of a constant, repetitive poll, the high-performance HPS (High Precision and Speed) series uses real-time, high-resolution absolute encoders to instantly determine the mount's precise position.
The mount's built-in intelligence controls and corrects tracking errors based on data from the encoders and a pointing model, which is a much more rapid process than the traditional polling used in standard autoguiding. The user-defined settings in the 10Micron ASCOM driver and external guiding software like PHD2 affect the timing of reactive guiding commands, not the mount's internal polling.
Thanks AstroStew for this valuable information.
Would the other ASCOM devices (camera, filter wheel, flip flat cover) be negatively impacted by increasing the polling interval to 10 seconds or does it not matter?
Jerry
Jerry Gerber avatar
AstroStew · Oct 19, 2025, 05:59 PM
Jerry Gerber · Oct 19, 2025 at 04:38 PM
Thanks,
Jerry
Jerry
They have no bearing on the control of the mount, so should not make any difference to those items
This is incorrect. Nina's polling interval does affect other devices. When I set the polling interval to 10” the autofocus routine took over 4 minutes to complete. When I brought it back to 2” autofocus completed in about 1 minute & 35 seconds.
As you correctly pointed out, my mount gets its tracking data from the encoders and from a good model, which I made a while back.
I'm going to ignore the log's warnings as they have zero affect on the mount's performance. From the information I gathered, 10Micron is very slow to upgrade its ASCOM driver to the newest ASCOM standards, which may well be the cause of these unnecessary warnings.
Question about GM1000
Yesterday there was a huge power outage in San Francisco where I live. It's still happening. My GM1000 mount is at a remote observatory in New Mexico and I am unable to access it as my Wi-Fi & power is down. All the equipment is turned off so...
GM1000 mount issue; discusses same equipment and potential troubleshooting approaches.
Dec 21, 2025
NINA Repeatedly Disconnects from Observatory Safety Monitor & Weather
Nina is repeatedly disconnecting from my observatory's safety monitor and weather. I should mention this is at a remote observatory, I'm some 900 miles away from my scope. I added the Reconnect: Safety Monitor and Reconnect: Weather to the Ad...
NINA connection problems; addresses similar software polling/communication issues with devices.
Sep 1, 2025
Solve & Sync
I am getting advice to delete Solve & Sync from the NINA advanced sequence because I have already built a 99 star model using 10Micron Tools. I am imaging unguided and getting excellent results. Should I follow this advice? Is the model itself al...
Direct relevance to 10Micron GM1000 mount and NINA integration.
Jun 15, 2025
CEM120EC real-world review with actual guiding metrics
CEM120EC — Real-World Review (With Actual Guiding Metrics) I realised something: there is almost no modern, accurate, real-world information on the CEM120EC. Most people only post when something breaks. So let’s correct the record because this mount ...
Mount review with performance metrics; relevant for understanding mount communication reliability.
Dec 7, 2025
