Help with odd QHY268M images
8 replies184 views
Jeffery Richards avatar
Image-APPM-2025-10-16-212413.txt-0341-RA_0.064-DEC_25.000.fit
Getting these types of images during a mapping run for my FSQ-85 on an AP1600GTO AEL. This is causing many plate solve errors and run results that are unusable. Any suggestions would be appreciated.
JORDI ZAMORA avatar
Hola Jeffery, a mi también me ha ocurrido de forma muy esporádica una o dos imágenes con un patrón parecido.
No le he dado mayor importancia ya que me ha pasado muy pocas veces entre miles de imágenes que he hecho con la cámara.
Jeff Reitzel avatar
Hi Jeff,
I see in your fits data that your USB traffic is set to 50 and you are imaging bin2. All info in the fits header looks normal to me with reasonable gain/offset settings etc. I cannot tell if you are using the ACSOM driver or not. First make sure that the box for “remove overscan area” is checked in the ASCOM driver if you are using it. This has been known to cause this exact problem you are seeing even though the camera is not recording the overscan area to display on the fits image. The other thing to try is adjusting the USB limit. Try 100 first and then 0 to see if it changes.
📷 268m.jpg268m.jpg Good luck and CS,
Jeff
Thanks Jeff! Pretty sure overscan is turned off but i’ll double check. I’ll also try tweaking the USB traffic settings.
Jeff
OKAY, may have found the issue. Somehow I had switched to the native QHY driver in NINA vice the ASCOM driver. I have switched it over and will test tonight. Wish me luck! I just moved my equipment to Howling Coyote Remote Observatory (HCRO) and hate missing out on prime data gathering time under these pristine conditions! I’m guessing during the install I inadvertently switch to the native drivers.
Jeff Reitzel avatar
Glad you found that driver issue. QHY native drivers seem flaky with any software other than QHY. I’d bet you're back in business. I've been wanting to put a rig at HCRO myself. Looking forward to seeing your images.
Jeff
Supportive
You will be very happy at HCRO. Great conditions and the support is first rate!
Jeff
So not only did I switch drivers, I also switched my main USB supply cables to USB2 ports. Things went well with the model tonight with no failed targets.
Thanks for the suggestions.
Jeff
Willem Jan Drijfhout avatar
Looks like you've solved it, congrats!  I've seen something similar to the colour version of the same camera. I eventually pointed it down to a low voltage of the power input. An aging field battery with a non-stabilised 12V output got to something like 11.6V by the time it reached the camera. When I connected to a stabilised 12V output, the problems were over. Is it possible that you see something similar with the USB-ports? USB2 requires probably less power than USB3. Perhaps it makes the camera less sensitive to small shortfalls in voltage. I have always kept USB3, because of speed of the file transfer.
Can't comment on the driver part, I use INDI driver.
Can someone help me identify this object ?
Wondering what this artefact (in screenshot) could be ? Was imaging M33 on October 18th in LRGB, RGB are each 15 times 120 sec, and this 3 color line showed up. Clearly a moving object that shifted over a time of 1.5 hrs across the field of view. Can...
Artifact identification may help diagnose image quality issues during mapping runs.
Oct 20, 2025
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
Meridian flip shifts could cause plate solve errors in automated mapping sequences.
Oct 28, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan vibration causing star trailing could explain plate solve failures in images.
Nov 18, 2025
Secondary and spider vein reflections appearing in my telescope images
Hi all Seeing if anyone has run into the issue if having flat frames that show the shadowing and spider veins of the secondary on the RC telescopes. Mine is the IOptron version but other brands may be the same. I know with the newer models, the baffl...
Optical artifacts like spider veins reflections could cause plate solve errors.
Sep 15, 2025
Looking for advice on removing vertical streaks in my Blue channel (M45)
Hey everyone, I’m running into a calibration/processing issue with my Blue channel on M45 and could use some help from people who’ve seen this before. My B-subs are showing strong vertical streaks coming off the brightest stars (example frame attache...
Calibration streaks in channels could degrade image quality and plate solving.
Nov 28, 2025
