Experience with Juwei-14 from Aliexpress
4 replies337 views
Alvaro Küper avatar
Hi all!
the reason behind this post is to make avaliable some real world experience with the Juwei-14 mount, as there is so little info online, so i hope its usefull for few of you looking for an alternative to more expensive mounts.
So, i got my Juwei-14 by end of august, now after 1,5months and a few sessions i can write some words on it, my setup at the moment on this mount is :
  • SW-ED80
  • Gemini focuser
  • Touptek 294mc pro
  • SVbony filter drawer (single)
  • guide: Svbony miniscope 30 & ZWO ASI385MC
  • ST-402C carbon fiber tripod
  • Mele quieter 3 mini-pc
Shipping:
mount was shipped from seller next day i placed the order, (July 02, and expected to be delivered on july 23) it leaved China in 2 days, and arrived to european customs a week later, it was holded on customs many many days. i contacted seller by begining august and he was very kind, explaining that astronomical equipment is often holded on customs due to similarity with militar equipment, it makes sense in my head, we also checked HS code ( customs identifier code) and was all correct. just a matter of 3 weeks more and the mount was delivered to me, packed well, inside precut foam and well sealed cardbox. all good. in total was almost 2 months, and clouds rolled over :)
Tripod:
in the meantime i ordered the carbon fiber tripod, super light (2,8kg) , with 3/8” attachment. it screws directly to the mount, im not using any extension pier. after fulling screwing it ( small note on that tripod: i found that the had some sub mm play, between the tripod head and the tripod plate. so not on the mount side, i solved it apliying some teflon thread to fill that minimal gap and worked perfectly. let see over time.. )
the ED80 is juuust long enoght, i had not have any leg crash yet during imaging (i had one crash, explained later)
contruction and quality :
the mount head is rock solid, all CNC anodized aluminiun, feels compact. its base adjustments for Alt/az i find it very smooth and satysfiing. dindt found any plays on it. easy to aling in about 5-10 minutes using NINA 3PPA
regarding the green laser pointer, i have collimated it, and it may be little off, but as a tip, after first polar align, now i know more or less where should i point with the laser next time to be in the ballpark to start 3PPA so no real need to keep it ON for more than 5 secs. always wathchout for planes!
Guiding:
im imaging with NINA and guiding with PHD2, at the begining had to try different algorithms, first test were horrendous, with an error over 2rms. none of configurations i found online worked for my mount. so there you have to experiment a bit. once i got the right config for my setup, my guiding values became more what im used too with my primary bigger setup.. under 0,8 and ocassionaly under 0,6 (once i saw it sub 0,4) and im guindig with short expousures of 500ms. BUT 2 important notes on it:
-polar alighment MUST be as good as posible. (total aligment error under 1’ is a must , much better if under 0,3’ )
-seeing conditons WILL affect your guiding with this short expousure rate. you will see it immediately how it changes in matter of minutes. so if your graph is little jumpy, do no desesperate. there is nothing you can do. just wait for your immage download and you will mostly find a good image, even if your graph is little jumpy.
i had have already about 15 sessions, and results are constants every time. depending only on seeing conditions, so im very impressed and satysfied with it.
important considerations:
  • the mount start traking as soon as powered on ( there is no power button, as soon as you plug it turns on and start tracking. i had plugged once during the day to access the mini pc, and then leaved on by mistake, only to find in the evening that it had crashed with itself, luckily i found no damages, but be aware it have lot of torque, so i was just lucky.
  • it have no GPS, but i connect from my smartphone via BT and give to the mount location and time with the onstep app. probably you dont have to do it everytime. but i had to do it ocassionaly.
  • it have no home sensor. so everytime it powers on, it asumens its at home position. my simple workaround was to level it at real home positions, make some marks on boh axes and the next time i have just to take it to the right positions and power cycle. no issues so far
  • slew-goto rate its slow, but i imaging mostly just 1 object/night so to me is neglible
Final thoughs:
this mount just works as expected, one correctly configured on PHD2 it just works, you just may spend 2-3-4 sessions setting up the correct values for your specifict setup; price wise, i paid for it about 600eur + 200eur on taxes at arrival; the “cons” i pointed on important considerations section, are very much subjective. so may or not be a con for you. my final idea with this mount its to put togheter a very capable and portable setup that i can trasnport on a cabin trolley for air travel and power it with usb powerbanks, wich i already tested, mount comsumption is very low, about 4w/h, i powered for abot 6 hours with a 25000mah powerbank with PD protocol.
i hope this “review” can help others AP’s in th ecomunity
Clear Skies! :)
You can avoid having it starting right at power up with the OnStepX App (SWS) or switch it off.
Rafał Szwejkowski avatar
It's ok, and it works, but it's noticeably inferior in "usability" and PE smoothness to AM3 and 5.  I'd pick AM3 over it any day, even considering the difference in prices. For others the savings may be worth it.
I own all of these and I've used them extensively.
Alvaro Küper avatar
Rafał Szwejkowski · Oct 15, 2025, 11:18 AM
sure i agree, my main mount is an Ioptron CEM40 w/Ipolar, usability, software, guiding and alignment are way better on it, but hey its a 3k+ mount.. for a portable setup i think this is the best ( or 2nd best) option ATM, if you are loading about 5-7kg
Jan Erik Vallestad avatar
I’m not going too much into all the details but they work just fine for medium focal lengths and smaller payloads. However QC is very bad and they are very prone to breaking. My vendor have confirmed the usage of low end parts, especially when it comes to electronics. Many new users “review” these after using them once or twice but people should really only review them after using them for an entire season at least. My J17 broke after six months with less than 20-30 active hours on it. I know many others who have the same experiences, too many.
I would never recommend these unless the buyer is prepared to, and comfortable with, buying replacement parts (most people can forget warranties) and solder/fix stuff themselves. The J14 is not an easy mount to work on and requires a lot of work if something goes wrong, the J17 is a lot roomier. Overall the parts used on these mounts are extremely low end and not made to last. Electronics wise they are hit and miss but also externally they suffer. Mine started rusting on several parts after a few months outside under a roof.
Research all the issues people have had before jumping the bandwagon. Mine works just fine now, and have done since I had to fix it back in January or so. But it cannot handle anything bigger than a 100mm refractor comfortably - and even that is a stretch on certain nights (For anyone that cares about sampling at least).
Still I feel like I’m just waiting for something else to fail. This doesn’t make for an ideal investment. In total, after repairs, I could have gotten the AM3 for the same amount approximately. My several years old AM5 still don’t show any signs of wear and tear..
There have been several informative threads online about these mounts. On CN there’s a very long runing one and there is also a Facebook group for users.
Link to CN
Link to facebook group
Helpful Insightful Engaging
