Beginner seeking advice on planetary imaging with Apertura telescope
2 replies•58 views
Vlad Tsymbalyuk avatar
Hey! Im basically new to astrophotography and i want to start planetary imaging (unguided) , i currently have a Apertura 10 inch dob and i want advice on which camera would be the best for my current setup. Thanks in advance!
Aloke Palsikar avatar
You can try with DSLR if you have one which is easiest and most simple for simple planetary imaging. Alternatively ZWO has a range of uncooled Planetary cameras like ASI 120 MC or ASI 662 MC which can work with your Dob. There are some cheaper ones as well from other cos which you may want to try out based on your budget. You will need to check how they interface to your laptop or other PC you may want to connect. If you plan to upgrade in future to proper DSO Photography you can look at investing in a Controller like ASI Air or any equivalent. There are enough reviews on You Tube on basics of Planetary photography which you can see upfront before deciding to buy
Hope this helps
All the best
In a push-to dob your best option is an IMX533 based camera. There are several vendors here so you can chose the one that best fits your budget.
Seeking advice on good planetary telescope recommendations
Hey there! I would like some ideas on what good planetary telescope I should invest in. I was looking into dobsonian telescopes but I’m not sure how good they are. So I would like to hear from some of the people here on their thoughts? Thanks!
Planetary imaging with dobsonian telescope directly matches poster's interests and questions.
Jan 31, 2026
Advice on Next Upgrade
Hi AstroBin community. I am an amateur astrophotographer looking for some advice as to what I should upgrade next. My current setup is: ZWO ASI533MC ProWilliam Optics New ZenithStar 61 IIWilliam Optics New ZenithStar FLAT 61AOptolong L-UltimateEQM-35...
Discusses camera selection for astrophotography setup upgrade decisions.
11 days ago
Planetary Camera for C11
Hey, I would like to restart after at least 10 years to image planets. I have a C11. Camera suggestion? Ty!!!
Relevant planetary imaging advice for similar aperture telescope and beginner context.
Mar 9, 2025
Planetary Camera Recommendation AP175 F8
I recently upgraded scopes to a AP175EDF F8 and am wanting to adjust my equipment/camera to match. I am also moving the setup into a permanent observatory that I eventually will have remote control over. I currently have an ASI462MC planetary camera....
Directly addresses planetary camera recommendations for telescope setup.
Large aperture planetary setup heavily underperforming for an unknown reason
So this Jupiter image i took recently, its somewhat decent i would say, but as im exploring this site i notice people getting far better results with significantly smaller telescopes and less data, makes me wonder what am i missing / doing wrong. For...
Troubleshoots planetary imaging performance with large aperture telescope.
Jan 20, 2026
