Triple Whammy
6 replies238 views
How (un)lucky is that? The only image of the object that I know of and I get THREE stray light beams! Crappy refractor.
Richard Carande avatar
So what is the source of these? I have an SCT and will get an artifact that looks very similar to what you have in the lower left, but can’t figure out its source.
It's an off-field star. They all are. Problem is I shouldn't have to have issues with those with a full frame camera.
danieldh206 avatar
The bad one on the corner can be fixed using the GAME with “Write shapes to Files/Views” to stack out the bad corner. Multi-scale gradient connection might be able to clean up the image.
I also know you have a fair amount of imaging experience and can figure it out. 🙂
AdamJ avatar
The older ZWO 2600, 294, 533 all have a reflective blue boarder around the sensor that causes this. They covered the boarder in a black band in the latest sensors used in the more recently purchases cameras. End of the day, if you park a bright star on that blue boarder (or the sliver edge) you get this exact effect in braud band images.
Except this was taken with an ASI2400. A brand new one.
AdamJ avatar
Irrespective of sensor type if it has the blue boarder it can create the issue, the 2400 has it from what i can see. You would have to look at your sample and see if it is present.
Imaging with oversampling? Are there any Techniques to it? Advice and discussion
Hey guys! This is general discussion and if you have any advice on the subject! I was wondering if there are any people out there that are imaging in particular deep sky objects (not planetary or lunar photography) with oversampling, either with long...
Discusses imaging techniques that may help reduce stray light artifacts.
Sep 8, 2025
How lucky imaging is applied correctly, Sky&Telescope 07/2025
Hi all, I live on the outskirts of a large city (Hamburg, Germany) and so far I have primarily been able to use lucky imaging techniques. In the July 2025 issue of Sky & Telescope I have published a 6-page article on Lucky imaging, check it out G...
Lucky imaging techniques could address stray light issues in imaging.
Aug 2, 2025
Serious Stray Light Issue - William Optics UltraCat 56
I’m posting this to see if anyone else has experienced or can verify this problem in their UC 56 telescope. I received the telescope February 2, 2026 from Agena Astro. The quality control certificate that was enclosed was dated December 5, 2025. The ...
Directly addresses stray light problems with telescope equipment.
Mar 1, 2026
