Deepan Vishal avatar
I am new to the QHY cameras. Currently using a QHY600 with Mele 2q mini PC. I installed the all in one drivers which seems to work.
But after every session, I turn off my PC. When I start next session, the device is no longer recognized and I have to re install the drivers.
This is frustrating.
Do anyone know what could be causing this? and is there a remedy for this?
Dave & Telescope avatar
Hi Deepan,
Make sure the camera usb connection to your pc is disabled before installing the drivers. I also leave the camera power off. If you haven’t done this, uninstall all the drivers, leave the camera power off, then reinstall, reboot the pc , connect the camera usb and turn the camera power on. If this doesn’t help or if you already did this, I would email cha@qhyccd.com. He is very helpful and will typically respond within a day or so.
HTH
Dave
Noah Tingey avatar
I had a similar issue — though I didn’t have to reinstall drivers, I just had to unplug + replug the USB going to the camera. I'm not sure what specifically resolved the issue, but it disappeared after I performed a fresh Windows install.
Something to help diagnose: When you freshly reboot your computer and the QHY600 isn’t recognized, does it show up in USB Tree View?
Well Written Helpful Respectful
MetaGuide won't recognize ZWO 585MC camera, missing directshow driver
I’m attempting to experiment with MetaGuide and I can’t seem to get it to recognize my ZWO 585MC. I know it needs the directshow driver but it’s no longer to be found on the ZWO website. When I run Meta the only camera it recognizes is the one in the...
Similar driver installation issue with astronomy camera on Windows system.
Aug 23, 2025
Screw size
Hi! Does anyone know the screw sizes of the Mele Quieter 3Q? Is it M3?
Author uses Mele mini PC; candidate discusses Mele 2Q with camera drivers.
May 16, 2025
PC power failure caused the mount not to connect in Sharpcap
I’ve created a major issue with my rig’s MeLe 4c PC not connecting to my HE5 Pro mount after a power failure via a power box. A Runtime error 62: input past end of file is shown, which given the log from Sharpcap seems related to a server issue, see ...
Device driver recognition issues after PC restart similar to your problem.
Nov 13, 2025
Polemaster camera not recognized on Windows 11 despite working on Windows 7
I have a Polemaster camera that I bought around 5 years ago. I used it with my old Laptop (Windows 7), and SharpCap. It worked great and still does with that laptop. I recently purchased a new laptop (Window 11 home), installed the driver/App package...
Camera not recognized on Windows despite previous functionality, driver-related issue.
Jan 27, 2026
Windows remote app on iPad
I’ve recently switched to a Mele mini pc and NINA to run my astrophotography setup and connect remotely via the windows remote app on my laptop. I know it’s also possible to use the Windows remote app on an iPad which could be very helpful when I go ...
Using Mele mini PC for astrophotography setup, relevant hardware experience.
Oct 14, 2025
