Seti Astro Pro Suite installation troubles
7 replies185 views
Sean Boon avatar
Has anyone been able to install Set Astro Pro Suite with GPU acceleration. I’m on an NVidia 4070 system and the Install/Update GPU Acceleration gets partially through and then complains about file locks.
Sean Boon avatar
This is one error I’ve been getting.
❌ Another install is running (lock: C:\Users\seanb\AppData\Local\SASpro\runtime\py313\.install.lock)
I also found the info topic that comes up has commands that are in py312 directory instead of py313.
I can load and run SAS, never been a problem but I too haven’t been able to get the GPU acceleration working. It get’s part way through and freezes or pops a file not found error.
Dunk avatar
Seti Astro maintain a Discord server (link on their website) - i’d post there for support.
bigCatAstro avatar
Sean Boon · Oct 12, 2025 at 11:41 PM
Interesting, what version of CUDA are you using? I wonder if Seti Astro Pro is like RC-Astro in that GPU acceleration only works with 11.8x.
Well written
Carl Gulbish avatar
The Discord server they have is very active. Frank is always on and willing to help. I’d check in there.
Sean Boon avatar
Ok. I’ll check out their discord.
D. Jung avatar
I had the same issue. Only thing that worked for me was to check out the python source and run it directly.
Enabling GPU usage on an NVIDIA card for RC-Astro tools
Trying to get this to work has been entirely hit or miss. I’ve tried simply the “experimental” repository method outlined on the RC-astro pages. That worked for a while but now my RC-Astro plugins BXT, NXT and STX are just slow, taking minutes at a t...
Directly addresses GPU acceleration issues with NVIDIA cards for Astro tools.
Sep 7, 2025
