SII-Rich Areas of the Northern Sky
8 replies229 views
Hello everyone,
I'm in need to test a SII filter (first time ever) and I'd need to capture some nebula which is both rich (and bright) in SII and poor in Ha and because of my northern latitude it would be best it be at least at +20deg N. Visible for most part of the night in, let's say, the next couple of months (British foul weather permitting). FOV about 1 degree square. All suggestions welcome.
Bob Lockwood avatar
The Rosette is a good one, +5, but the Ha is really heavy. The California is also good, about equal in Ha and SII if +36 isn't too high.
This is a single 15 min with a 3nm and a 16803.  These are big, forgot you're looking for about 1 deg.
NGC1499 / California_2020 (Bob Lockwood) - AstroBin
Morian avatar
IC 1805 (Heart Nebula)
Rick Krejci avatar
You can look for predominantly blue areas here: https://simg.de/nebulae3/dr0_2/
I went here ( Overview image of DR0.2 of Northern Sky Narrowband Survey in [SII], H-alpha, and [OIII]) and the most likely candidates  (for my location) are the following:
LBN 560-551 SI-2
SNR G132.7 +1.3
HDW2
And later in the night:
SH2-221
SH2-216
Obviously NGC1499 and IC1396 are also rich in SII but unfortunately very strong in Ha too.  I have no idea how strong is SII in the listed above nebulae. Maybe someone managed to captures some of them in SII?
Brian Puhl avatar
andrea tasselli · Oct 12, 2025, 08:17 PM
IC 1396 in Ha and Sii. Sulfur isn’t brighter than the Ha here by any margin.
Aformentioned IC 1805 (Melotte 15) has an extremely bright Sulfur region, and while the Ha is equally as bright, it showcases a substantially different structure. Hope it helps a bit
These targets hardly fall into the realm of what you’re asking for. I’m not sure they exist.
Thanks guys for the suggestions. I'll try Melotte 15 as it seems the most promising and hopefully enough to differentiate the Ha from the SII. I'll try odd ones when time and weather permits.
Marco Montella avatar
This website isn’t super up to date, but it provides an overview of the relative contribution of S/H/O in a fairly large catalogue of popular nebulae! https://www.galactic-hunter.com/post/filter-expectations
It’s a great resource that I have used many times to double check that my S+O filter was not defective 😅
BlackStarsAstro avatar
Thanks everyone. I was able to learn about two resources that I was not aware of. Im absolutely sure these will help me capture targets based on what I am actually trying to/expecting to obtain in my data acquisition.
Marco Montella · Oct 13, 2025 at 11:46 AM
Rick Krejci · Oct 12, 2025 at 07:54 PM
“Unless you need rain, Clear Skies”. Pat Prokop’s Heavenly Backyard Astronomy
New to or Considering Astrophotography/astronomy?
I had posted this with a new image I’d uploaded as a change from the “typical” review of my processing steps/acquisition. A friend/commentor suggested I post in a forum, so this is the result. This is VERY subjective and based entirely on my experien...
Author seeks specific nebula targets; this resource helps beginners learn astrophotography fundamentals.
Jul 31, 2025
Laida SHO 5nm filters first light test
On my mono setup (ASI294mm) I originally used all the legacy 1.25" filters that I had/have, Astronomik IIc for LRGB and a mixture of Astronomik, Baader and Astrodon True-Balance for NB (Hb, Ha and OIII). Never actually had any SII filter previou...
Author mentions needing SII filter; post discusses SII-rich nebulae for testing.
Dec 13, 2025
