Adrian Webster avatar
Afternoon all.
I’m after a bit of help.
I am just setting up my first SC type scope (Celestron EdgeHD 8) for planetary.
I can get focus with the following image train:
OTA>visual back>Camera (ZWO 679MC with UV filter) via nose piece.
When I fit a x2 Barlow, I can also get focus.
OTA>visual back>Barlow>Camera (ZWO 679MC with UV filter) via nose piece.
📷 IMG_4473.JPGIMG_4473.JPG📷 IMG_4472.PNGIMG_4472.PNGBut for the life of me, I can’t get even close with I fit the ADC.
OTA>T piece >ADC>Camera
📷 IMG_4474.JPGIMG_4474.JPGI can see the T piece and ADC push the camera back a good 2” difference in back distance, which i’m guessing is the issue.
So my question is, what do I need to be able to focus with a ADC fitted?
David Foust avatar
It looks like the ADC corrections are set pretty high (the two levers (one pointing up and one pointing down). This may be giving you a result that looks out of focus. I think the ADC neutral position is when the levers are in the same position, and parallel to the horizon. Maybe try resetting the levers to the neutral position?
Otherwise, you may have run out of back focus with the ADC. Have you measured the backfocus of each setup?
Most folks will put the ADC behind a telecentric Barlow, which means backfocus and Barlow effect are less sensitive to backfocus issues.
I’ve retested with the ADC correctly set up (I had just thrown that on for the photos) but I still can’t focus on far away objects. I’m guessing the back focus is wrong, but everything indicates I should be reducing the back focus distance, which I can’t actually do, as the visual back is a set length.
Your T-adapter is seriously long, you need to buy a shorter adaptor..
Robin Bosshard avatar
Is that the t-adapter at full lenght? The one I use is a two-part design so it can be shortend for use with the reducer. Hard to see in the pic…
Robin Bosshard · Oct 11, 2025, 05:36 PM
Had a chance to check my setup, and, yup, that’s the t-Adapter already at half length.
I did a quick comparison with the visual back combined with the universal t-adapter from Celestron, but that makes no real difference. So, maybe some other, shorter visual back that allows for a shorter t-adapter? I think Celestron doesn’t offer something like that, though. I will have to look into that myself since I can just about fit my rotator and filterdrawer in when using the shortened t-adapter with the C8 without the reducer on, but with the reducer I will have the same problem. So if you find a nice solution, let us know!
T-adaptor is just a glorified name for a M42 threaded adaptor. Just get one of the suitable length.
andrea tasselli · Oct 11, 2025, 07:46 PM
With Celestron/C8 it’s the other end that complicates things…
Craig Towell avatar
Stick the barlow lens cell on the nose of the ADC, should hopefully push the focus point further out to allow you to focus? Or if you don’t want to use the Barlow you could remove the top part of the ADC and screw the camera directly to the prism module.
Concise
OK, problem solved!
I could have just deleted the thread, but i’m going to put my hands up here, and tell the truth. I was using a EAF to focus, and like a biff, when it got to the end of the run, it didn’t dawn on me that the C8 mirror still had space to move.
I took of the EAF, manually focused with the ADC, and then put the EAF in the middle of its run, and refitted it.
Job jobbed!
Sorry for being a biff and wasting everybody’s time!
Still, lesson’s learned!
Helpful Respectful
David Foust avatar
No worries. Glad you got it sorted out!
Back Focus Frustration
I am trying to stitch over my ASI533MC Pro with ASI Filter Drawer and the required 16.5mm spacer for that party of the image train to reach a back focus of 55mm. I know that is solid because I have used it for years on my refractors. I am finally try...
Discusses image train and focus setup with similar Celestron scope configuration.
Mar 24, 2025
APM 2" Barlow 1.5x
Hello . If anyone is using this Product . I need help ! APM 1.5x Barlow telecentric for Visual and astrophotography. I have the backfocus right….(i think) but cant see any stars or trees because i tried during daytime also . The focuser tuber w...
Focus setup and adjustment procedures for telescope imaging systems.
Aug 24, 2024
PrimaLuce Lab - ESATTO 2" LP and Celestron EdgeHD 8
Hello, All. I would like some help, please. I am currently imaging with the EdgeHD 8 and the ZWO EAF when imaging with the Celestron Reducer at F7 my current back focus is 105.3mm, with the following components: 0.7x Reducer, SCT Adapter - 25.3mm, Ce...
Covers image train setup and focus configuration for EdgeHD 8 scope.
May 15, 2024
