Benefits of upgrading from AM5 to observatory grade mount?
BlackStarsAstroRobert ŽibregTony Gondola
25 replies700 views
BlackStarsAstro avatar
What would be the benefit of upgrading to a “observatory grade” mount?
I currently run a Celestron EdgeHD 11 native FL-Zwo 2600mm camera-Zwo L oag-zwo 174 mini guide cam-Zwo 2in 7 position filter wheel-Esatto 2” focuser-mele quiter pc-wanderer astro wanderbox pro v3 on a AM5 mount with counter weights on a concrete pier. my guiding is .4/.5. Can anyone explain. Im look at the skywatcher EQ8. Thanks
Robert Žibreg avatar
I was also advised to upgrade from AM5 to observatory grade mount but for now I don't see any benefit. Guiding is 0.4-0.6 depending on seeing. I would only upgrade if my setup is over mount kg limit.
Bill McLaughlin avatar
IMHO, none of the Chinese mounts are “observatory grade”. Observatory Grade mounts are mounts like those from AP, Planewave, ASA, 10 Micron and (maybe) SB.
They may get there someday but that day is not today.
Speaking as an EQ6R-pro owner, the 8 is a nice mount with some great refinements. Its payload capacity certainly puts it in the “observatory class”. On the other hand, carrying the kind of payload it’s designed for, I wouldn’t expect better performance then what you are already seeing. Along with great payload capacity I’d also be looking for refinements like encoders. sky modeling, limit switches and so on.
Yves Ouellette avatar
If you are happy with the performance of your mount I would not recommend upgrading. I would argue that you are at the limits of the capabilities of the AM5, but that is up to you.
The EQ8 is a great mount but you need to decide what is it that you want to gain with the upgrade.
Georg N. Nyman avatar
“Observatory grade mount” - what do you have in mind? The AM5 is a tiny and rather weak little mount, nothing else!
Any well known larger mounts from iOptron, Skywatcher upwards are lightyears better than that little thing.
Observatory grade - then you talk about 10Micron, AB, SB, Planewave and ASA. But I am pretty sure, you do not need such a mount - especially coming from an AM5.
Look at EQ8R-Pro, iOptron CEM120EC2 and similar mounts, I am sure those types are more than large and stable enough for your plans.
I am a user of both plus an EQ6R-Pro and all of them are fine. On the large iOptron, there is my 12”Truss and on the EQ8R-Pro the RASA11… both mounts well under their photographic payload limit.
Thanks for all the comments. I think whats being said is that as long as I am satisfied with my current setup, stick with it. I was just wondering if it would make a massive difference in image quality and guiding. I am satisfied currently with both. I do not plan on getting anything larger than the EdgeHD11. I just need darker Skies😀
Thanks
ScottF avatar
If it isn’t broken, don’t change it. It looks like you have good guiding with what you have, so I would stay with it until it no longer performs that well, and put the money towards something else……like another scope!
Well Written Concise Supportive
ckhorne avatar
Georg N. Nyman · Oct 8, 2025, 06:39 PM
“Lightyears better”? Under what metric? I need my mount to move my scope and keep it on target, ideally with little fuss.
My AM5 (with a fully loaded 9.25” SCT @ ~36lbs and 2300mm) can routinely guide in the 0.4” RMS range, and “just works” every time. No mess, no fuss.
I manage a CEM120EC for a local school. Adjusting the belt tension is a pain. The software in finicky. Maintaining alignment requires leaving it always powered. It’s a pain. Does it have a larger weight capacity? Sure. Does that mean it’s “lightyears better”? No. If anything, I’d rather have an AM5 if it meets the weight requirement.
To the OP: Define the problem you’re trying to solve first, then find the solution.
ScottF avatar
ckhorne · Oct 8, 2025 at 07:47 PM
Wonderful plot!
Gilmour Dickson avatar
ckhorne · Oct 8, 2025, 07:47 PM
Bob Rucker avatar
I am a huge AM5 fan but when I purchased my EdgeHD 11, I made the decision to upgrade the mount so as not to run so close the the AM5’s capacity. I considered many traditional mounts like the EQ8, Paramount MyT, etc. In the end, my positive experience with strain wave technology led to me pick the iOptron HAE69C-EC.
The HAE69C-EC is by no means what I would call “observatory grade” but it is meeting my needs. The main advantages over the AM5 I’ve observed include the following:
1) No counterweights required for my fully loaded EdgeHD11.
2) The encoders allow me to run long (5 second) guide exposures which is handy when imaging at f10 and there’s few guide stars in the OAG.
3) Set-up time is comparable to the AM5 once you get used to the quirky polar alignment adjustments.
I’ve previously used traditional mounts like the HEQ5 Pro and prefer the simplicity of strain wave mounts. The main advantage I see with a mount upgrade (traditional or strain wave with encoders) is the ability to run longer guide exposures if using an OAG. My experience with the AM5 demonstrated significant guide degradation when using longer exposures.
What you write, does not mirror my experiences with my CEM120EC2 - I have it outside since I purchased it about two years ago and it runs my 12”Truss at 2400mm focal length with an 475mm APO on top of it. The average error is about 0.2-0.25”, the software never had a single glitch and for me it is easy to handle, understand and manage. I always power it off and everything remains as it was before and belt tension….- well, I never touched anything and it runs just fine.
Having said this, probably I am lucky with my mount and you have bad experiences with iOptron.
That is a very interesting point. One may acquire an exceptional mount or just a good mount. My AM5 has always run 0.1-0.2 with my Svbony 122/ SQA 55. I imagine it depends on the production run date.
BlackStarsAstro · Oct 9, 2025, 01:25 PM
arc/sec or pixels?
ckhorne avatar
Georg N. Nyman · Oct 9, 2025, 06:18 AM
I would suspect it comes down also to the situation and the operator. PHD2 can be finicky to get dialed in, and that can be true with any mount.
My point was that a lot of modern mounts are capable, as long as you respect their limitations (especially weight range). I think modern guiding software is largely to thank for this, and that really blurs the line of what an “observatory class mount” actually means. I wouldn’t consider the AM5 to be in that class, but then again, it works very well for me, so I wouldn’t discount it as incapable.
Having said all that, my 9.25” pushes it at the limit (I do use two 11lb counterweights). I wouldn’t consider it adequate for a C11. If they made an AM7, then it may make sense (and I’d personally upgrade).
Well Written Insightful Respectful
Tim Ray avatar
I have an IOptron CEM70EC-Nuc mounting. Mounted a 10” Steel tube RC on it. First night out of the box, polar aligned with SharpCap, 1200 Sec subs! My MyT didn’t do that on its first night and can’t do that still even with a 914mm FL WO 132FLT mounted on it. Just saying…
The only thing that bothers me with AM5 is in fact driver support.
  • slew to alt/az stopped working for me for some reason, it can only slew to ra/dec
  • custom parking support
  • parking in general will hang in NINA
I’m sure there’s more. This is the only reason I would upgrade to something with robust driver support.
Robert Žibreg · Oct 16, 2025 at 06:48 AM
I have a similar experience with parking scope in NINA. Park will work flawlessly for months and then it stops. Idk if it’s the AM5 or NINA.
BlackStarsAstro · Oct 16, 2025, 01:03 PM
I don’t know if it would help but when I unpark my mount in NINA I always click “set as park”. Not sure if it’s needed in my case, it’s just an old habit but I never have parking issues.
Tony Gondola · Oct 16, 2025 at 04:20 PM
I get an ascom alert that this mount doesn't support set park position. I run the nightly.
Noah Tingey avatar
I’m surprised that nobody has mentioned this yet:
IMO, in this hobby, a key differentiator between an “observatory class” mount versus other mounts is its ability to operate unattended.
  • Is it capable of slewing into the pier?
    • If it does, does it destroy something? (Strain-wave geared mounts often do)
  • Can it recover from an unknown position where it cannot platesolve?
    • Or can it at least remember its position through a power outage?
To me, these matter much more for observatory operation than whether it can carry X kilograms of payload or guide within Y arcseconds RMS.
Well Written Helpful Insightful Concise Engaging
Robert Žibreg · Nov 8, 2025 at 07:09 AM
What are we looking at here?
BlackStarsAstro · Nov 8, 2025, 01:14 PM
You are looking at AM5 mount with OnstepX FW added instead of original ZWO board. This fixes numerous reported issues that ZWO simply refuses to fix
