Beelink 12V box PC power supply
5 replies111 views
Arun H avatar
Hello, I have a Beelink box PC that I would like to start using for field acquisition.  The Pc runs off of 12V. Using a simple wall wart, I have no issue getting it powered up and set up. However, for some reason, it will not power up when connected to either a LiFePO4 battery or connected to a 12 V regulated powerwerx power supply. For those of you than run PCs off of battery, what power supplies do you use and do you have an explanation for what I am seeing?
Have you checked that the delivered voltage is above 12V?
check the amps also…
Arun H avatar
@andrea tasselli - good suggestion, I will test the actual delivered voltage of the wall wart using a multimeter.
@Tony Gondola  - I don't think amps are the problem. The Powerwerx supply I used is rated for 40 amps.
Quinn Groessl avatar
Pegasus software says 11.3-11.5 amps most of the time when I’m imaging. I have mine plugged in to my Pegasus Powerbox and it works fine like that.
Arun H avatar
Problem solved…. bad barrel connector at the end of the powerpole cable I was using to plug into the PC.
Power Station for occasional use
Hello all, I know this topic comes up a lot, but i’m trying to consolidate my research with a few opinions of those who might be in the same boat as me. My normal set up at the moment is a SA GTi mount, with a REDCAT 51, ASI533MC Pro, filter wheel, E...
Discusses power station solutions for occasional battery-powered equipment use.
Aug 31, 2025
Power issues!
Hi all, I'm having some issues with powering my astro gear. Whenever current draw is high (like when cooling camera), my input voltage gradually drops until it is near 10.5V. Obviously, this is not ideal for the equipment, but simply purchasing a...
Discusses 12V power supply issues relevant to astro equipment powering.
Apr 8, 2025
CEM70 Disconnects via USB
Hi All, I've been having a recent issue with my CEM70 dropping connections. I have the CEM70 connected via USB to a mini PC. It is powered by a 12v 5a adapter that is plugged into the wall. (via power brick) I've run this same config for abou...
12V power supply setup for PC; directly relevant to power configuration.
Nov 26, 2023
Power solution for AM5N + ASI533MM Astro rig
Hey guys! I have the ZWO AM5N, ASI533 MM Pro, ASIAIR Plus, 120mm Mini, and dew heater for the Carbonstar 150mm reflector. Is the Bluetti AC70 (1000W and 768Wh) capable to power this setup comfortably? What other batteries do you guys suggest for a se...
Addresses powering astronomy equipment from battery power supplies like Bluetti.
Jan 4, 2026
How to end overnight session
Hi! I am wondering what people do at the end of an overnight imaging session. Does it matter if the scope just stops or do you let it slew back into home position? I am using the Asiair and had some power troubles. Using a poor power cable, the Asiai...
Power supply issues directly relevant to your Asiair power cable problem.
Feb 22, 2025
