Mossyback avatar
I’ve finally got PhD2 working reasonably well but with one exception and I’m not sure how to fix it.
Guiding appears quite good but the PhD2 program sometimes “times out”. Is there a setting that I can adjust to remedy this situation? I’m assuming that this is occurring after a filter change as guiding is suspended during that event. In case it is relevant, I’m using N.I.N.A. with a SB MtY mount.
Hank
Ron avatar
Hank,
I don't recall the exact issue I was having with PHD2, NINA, and my MYT mount, but I have been in contact with Software Bisque and have received an updated Telescope Adapter driver.  I used it during the last new moon and had no issues.  You might want to reach out to them to see if they can provide it to you.  I searched their site but did not find it listed.
Ron
Well Written Concise Supportive
Jim Waters avatar
Have you posted on NINA Discord?
https://discord.com/invite/rWRbVbw
Jim
Narrowband Issues
I decided to expand my astrophotography into narrowband imaging. My budget has allowed me to get three 5nm filters. Last night I tried out the H-Alpha filter using N.I.N.A. and immediately ran into a couple of problems. Autofocus is not working well....
NINA filter changes may affect autofocus settings like your narrowband setup.
Jul 29, 2025
camera use conflict with two zwo cameras; one for imaging, one for guiding
Here is my issue: I use a zwo asi 2600 imaging camera via SGP and then have tried to use an AsI Zwo 220 mini for guiding via ascom on PHd2. The problem is the PHd2 software reads the pixel size not at 4 but at the size for the 2600 camera. This occur...
PhD2 guiding software involved but timeout issue unrelated to pixel size.
Aug 31, 2024
What do you do when PHD2 sees ghosts?
I have been chasing a problem in my guiding for several hours yesterday night and tonight. I use an OAG with a SCT (C8); PHD2 (managed by NINA) is the brain. The experienced problem was that, for a specific target, guiding would work well “in most ca...
PHD2 guiding timeout issue with NINA and mount similar to author's setup.
