Colour of interstellar dust
6 replies187 views
John Walsh avatar
I have been looking at many images of dust, such as is found around the Ghost nebula for example. It varies from brown to reddish brown to yellowish etc but I’ve also being seeing a lot of dusty images where the dust is almost white (not the grey of IFN). These seem to come from low Bortle areas with very high integration time.
So my (probably stupid) question is: Is this dust colour solely a function of post-processing or is there some other factor at play, like LP levels, mono with LRGB vs OSC etc?
Thanks for your patience if this is a foolish question
Different dust and dust environments will give a different hue, plus difference in calibration and rendering. I'd like to think this is as neutral as possible:
Overview image of DR0.2 of Northern Sky Narrowband Survey in RGB without H-alpha.
Mikołaj Wadowski avatar
My guess would be poor LRGB handling (overstretched Lum/understretched RGB) or not enough integration in RGB. Depends on the image, really. Sometimes it might be the difference in white balance choice, though I don’t think this is very common.
I guess the right answer is the mixed color of the starlight that illuminates it. I would think that because of that, it can vary but not a lot. In most good images I’ve seen it’s pretty neutral and as such it would be a very sensitive indicator of color issues. Almost like a grey card in conventional photography.
John Walsh avatar
Thanks for the replies! It’s just interesting to me to see the variation in dust colour from the same object across images. Not sure if it matters from an artistic standpoint but I just thought it was curious
Tony Gondola · Sep 26, 2025, 11:26 PM
Depends on the dust. What you said can be applied to IFN/high latitude dust, but as I understand it, OP is talking about the dust close to the galactic plane since they said
John Walsh · Sep 26, 2025, 08:56 PM
not the grey of IFN
The dust near the galactic plane is in general a fair bit redder than the IFN as shown by the NSNS RGB data, linked by Andrea. If you find an image with grayish/neutral dust in say, Cepheus, than it’s very likely a processing error. Far more likely than a deliberate choice, like different white reference imo.
Helpful Insightful
Brian Puhl avatar
Trust the color calibration, this is your accurate color. It’s not uncommon to make subtle tweaks in the dust of a broadband image for taste however.
That being said, don’t always trust other folks imagery. Ha can be mixed with the dust. If an HaLRGB image is not processed utilizing continuum subtraction, then the resulting image can be very inaccurate.
Helpful Insightful Respectful
Benefit of shorter exposures?
Since I got my ASI533MC-Pro, I've usually been using 300s exposures, although I have seen many other people using shorter exposures, and getting low-noise images in a fraction of the time I am (With similar sized telescopes, a 130mm F5 reflector)...
Feb 12, 2024
Both posts discuss how different imaging parameters and techniques affect the appearance and quality of astronomical observations.
Interference-Style LP (Maybe even enhancement) filters, Fast Short Optics and the Problem with Long Period Variable Stars! Lesson Learned?
The following is something that I just posted with my last image, since it is relevant to the data generated and processed. I am partially reposting here, and changing where appropriate to those who may not see my image Rosette West Widefield - In OS...
Feb 18, 2024
Both posts discuss how observational conditions and equipment choices affect the appearance of astronomical features in images.
