Thoughts on my collimation of 9.25 sct
3 replies•97 views
Tom H avatar
📷 Light_M 57_20.0ms_Bin1_533MC_gain100_20250922-194256_13.6F_0004.jpegLight_M 57_20.0ms_Bin1_533MC_gain100_20250922-194256_13.6F_0004.jpeg
Bill Dirks avatar
From an EdgeHD 9.25 noob:
Choose a star overhead.
Defocus by moving the focus knob in the same direction as the autofocus when it finishes. I heard should be counter-clockwise.
Make sure the star is centered before judging the collimation.
Given that, the image is very close, hard to improve, but I see it a little fatter to the lower right. You'd be forgiven for stopping there, though.
Don't overtighten the screws. Just tight enough so they hold. Overtightened screws will give distorted star shapes.
Should hold collimation a long time. But it's easy to check if you suspect it's gone a little out.
John Tucker avatar
I think that if you really want to nail it, you’re supposed to get it as good as you can, then pick a less bright star (or reduce your exposure time) and see how it looks with the star closer to focus.
Also you want to make sure that the donut looks the same on both sides of focus.
Tom H avatar
Thank you for the insights
Seestar S50 file organization: keeping thumbnail and JPEG files?
The Seestar S50 produces two directories for each object. e.g. M81 M81_sub The sub directory contains (for example): Light_M 81_10.0s_IRCUT_20260328-224521.fit Light_M 81_10.0s_IRCUT_20260328-224521_thn.jpg Light_M 81_10.0s_IRCUT_20260328-224521.jpg ...
File naming convention matches Seestar S50 output format from source image.
Artefact in image
Need help for artefacts in my image 5867.jpg Here's a jpeg link of starless HA IC2177 . You can see artifact everywhere but especially in the corners . Does someone have an idea of what this is ? About 50min of integration Sharpstar 13028hnt Antlia h...
Image artifacts troubleshooting relevant to JPEG quality issues shown.
Feb 13, 2026
Weird Artifacts when shooting with SCT
Hi, I’ve noticed I get a weird border artifacts on all sides of the picture when shooting with my SCT. I did not have this problem when I use the same camera/filter on a refractor. Anyone know what is causing this and how to fix it? I’ve shot multipl...
SCT border artifacts directly applicable to source image problems.
Sep 22, 2025
Any suggestions: trouble achieving sharp focus with Edge HD
Recently I bought a second hand Edge HD 8. The tube was bought 4 years ago and in very good shape. Collimation is - as far I can see - all right. My main problem is: I can’t find good focus. Recently I captured the moon and Jupiter . Although PixInsi...
Focus sharpness issues relevant to achieving crisp results with SCT.
29 days ago
