Can anyone tell me the swing radius of a CEM 120
13 replies137 views
Read noise Astrophotography avatar
Hi, I was wondering what the swing radius of a CEM 120 is?
Measure from the centre of the pivot point to the end of the RA shaft and this is the swing radius of the mount..
Also is anyone using the 120 EC is it worth the extra money ?
Reg Pratt avatar
From RA pivot point to the end of the cw shaft is 25”.
Thank you very much .. it should squeeze into place ..
Reg Pratt avatar
Correction, it's 25” my bad.
Reg Pratt · Sep 20, 2025, 02:07 PM
But is that from the center of the pivot point or the length of the CW bar?
📷 image.pngimage.png📷 image.pngimage.pngTrying to work out if I can squeeze it in to my mini Obs do do I need to build a new Obs.. hopefully it fits wit out cutting the CW bar really dont want to do that..
My CEM 70 is 21” from the pivot point to the end of the CW Bar
Reg Pratt avatar
Read noise Astrophotography · Sep 20, 2025, 02:15 PM
From the RA pivot point.
Reg Pratt · Sep 21, 2025 at 12:02 AM
Thank you 🙏
CS!
AstroStew · Sep 22, 2025, 09:42 AM
If you are concerned it’s too long, then what I did on my CEM70 was bought the extension for the counter weight shaft and took the original out and fitted the extension straight into the mount, it just screws in, in its place, this is great as the extension is a few inches shorter than the original bar, so you then have three options of length bars, original, original and extension, or just the extension. Simples 😀
You Sir !! are da man ! Thanks you very much !!
How long is the extension??
