Matching sensor corners with subs corners
4 replies•138 views
patrice_so avatar
Hi there,
I have a quite significant sensor tilt issue. Hopefully, I just saw a great thread on Cloudynights revealing that the M42 adapter plate delivered with my touptek ATR2600m can be used as a tilt adapter if one add 6 M2.5 grub screws.
https://www.cloudynights.com/topic/910082-touptekrisingcam-imx571-tilt-adjustment-using-filter-mount-screw-holes/
My question is the following : in order to tune tilt, I need to get an understanding of which sensor corner match which image corner. To put it another way, I need to understand if the image in my file corresponds to the image on the sensor seen from the back of the camera or from the front of the camera. I tried to find some illuminating posts on this issue, but, so far, everything appears confusing.
A hint is much appreciated here.
Patrice
Simples. Take (make) a 1/4 circle of dark paper so that it fits (and sticks) to whatever corner of the camera window and covers at least few square mm of the corner's sensor. Take a flat and you'll know.
patrice_so avatar
Thanks @andrea tasselli!
Hopefully you are there to promptly solve issues that should been solved without disturbing the community 🤪
I just figured out that the ATR2600m is to be looked from behing the camera to match the image in the screen, with that particularity that the image is rotated by 180° with regards to the inscription at the back ot the camera.
Now I wait for my grub screws.
Thanks again, clear skies,
Patrice
John Hayes avatar
I just pull the camera, put a piece of tape across one corner of the camera to intercept the light path, and remount it. It just take a minute to figure out the orientation. The one recommendation that I have is to clearly mark your camera so that you can read the orientation long after you’ve forgotten which side is which.
Just back from shop, tilt screwing sticking out too far to put on filter wheel
Hello all! I just got my ZWO 2600MC AIR back from the repair shop for a sensor board replacement (artifacts in images) and motherboard replacement (bad set of usb ports). I think they either did a great job and did a tilt adjustment for me, or they f...
Both posts describe problems with camera sensor tilt adjustment on astronomy imaging equipment.
17 days ago
Unable to achieve focus after reflector modifications
So last week I received my new spider, primary mask and rear plate(?) off AliExpress (link for reference - https://www.aliexpre....51d31802lnldIB) for my Sky Watcher Quattro 250P F4 My steps so far as follows: I installed the spider and mounted the s...
Both posts discuss troubleshooting and component modifications for astronomical imaging equipment.
Aug 10, 2025
Question about Wanderer ETA and multi-night registration
Hi everyone, I don’t have the WandererAstro ETA (Electronic Tilt Adjuster) yet, but I’m seriously considering it and I’ve been thinking about a possible side effect. As far as I understand, the ETA adjusts each corner of the sensor independently. Thi...
Both posts discuss methods for correcting sensor tilt issues in astronomy cameras.
Aug 31, 2025
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
Both posts describe technical problems encountered during astronomical imaging that require troubleshooting and adjustment of equipment.
Oct 28, 2025
