Starizona Nexus .75 reducer Coma Corrector works perfectly with 2600MC AIR/DUO
ZWO ASI2600MC DUO 2 replies187 views
Michael Gehrisch avatar
I am using the ASI2600MC AIR (same camera and guide sensor as DUO) on an ONTC 800/200, and recently purchased the Starizona Nexus .75 reducer Coma Corrector without realizing that it claims to have an image circle of 28mm (APS-C size), while the onboard guide camera on the ASI2600MC AIR/DUO officially needs an image circle 43mm. So according to the specs this combination should not work. But in fact the guiding was just as good as always even when using an Optolong Ultimate filter, below .5 arcsecs on average mount Rainbow Astro 135E. So the onboard guide camera seems to do quite well even when not fully illuminated... YMMV
📷 M31 First light with Starizona Nex... (2nd session with Starizona Nexus .75 CC on ASI 2600MC AIR + Narrowband Optolong Ultimate)M31 First light with Starizona Nex... (2nd session with Starizona Nexus .75 CC on ASI 2600MC AIR + Narrowband Optolong Ultimate)
https://app.astrobin.com/i/mm0n43/
Helpful Insightful Engaging
shenmesaodongxia avatar
Stunning results! I have a question. Does the guide scope have a dark corner?
shenmesaodongxia · Nov 7, 2025, 12:05 AM
Not that I have noticed, since using the 2600MC Air is so easy, the only contact I have with the guide camera is when calibrating the guiding, and there are no dark corners on the calibration screen…
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Discusses coma corrector with guide camera setup; relevant to your optical configuration.
Mar 13, 2026
