super Luminance on all RGB SHO channels?
10 replies350 views
Arny avatar
What are your experiences with synthetic “super Luminance”, ie. integration of all available channels?
  • L+RGB channels
  • L+RGB+SHO channels
I have the impression contrast and SNR improve - but does it really lead to better results?
SNR isn't an impression, it can be measured. But to answer the question, yes, they tend to lead to a better results if the quality of the RGB/HO integrated light is of a comparable level to the L channel and the right procedure is followed.
Kevin Morefield avatar
I always use a SuperLuminance when doing LRGB. The gain in SNR is measurable. Unless your RGB subs have higher FWHM’s I can’t think of a reason not to do a SuperLum.
With Narrowband I usually do a PseudoLuminance. Unlike the SuperLum where you have ImageIntegration do a weighted combination of the LRGB masters, with Narrowband I combine the channels manually in Pixelmath using factors. The idea here is that we generally reduce the strength of the Ha so much trying to get NB colors balanced that the SNR is seriously degraded. So I usually do something like Ha*.5 + OIII .25+ SII*.25 to try and lean more on the Ha for SNR. But you have to be careful that there is enough of the O and S in there to support their particular structures and not have colors with no Luminance behind them. Even equal amounts of S, H, and O will have a better SNR than your SHO color mix though.
If I’m doing SHO+RGB I’d probably test some combinations of extracted L from the RGB master and the SHO masters.
Helpful Insightful
If you have decent skies try no filter and get everything your sensor is capable of recording. Every photon has a home….
Arny avatar
Thanks for your advices and sharing your experiences, guys.
Apart from Kevins advice to always use synthetic Luminance for narrowband images - are there alternatives to benefit from the SNR of a superluminance?
How do you deal with the issue that the Lum channel or any super Luminance are less sharp than the SHO image, yet have much better SNR.
BlurXTerminator I tried but did not make substantial change.
So what is best practice for making use of a Lum channel with SHO images?
Arny
Pi uses the L*a*b model so any sharpening will be carried out on the L part of the image hence the use of synthetic L (out of a SHO imagery) pretty pointless in that regard. This said, if you want to "sharpen" an image then use UnsharpMask not BXT, it is not its job.
Arny · Sep 15, 2025, 08:47 AM
Arny
I want to make sure I understand your question. Are talking about adding Luminance data captured with a Luminance filter to SHO color data?
If so I would not add pure L data as a Luminance channel when the color data is pure SHO. Differences in sharpness would not really be the issue there but the differences in the actual structure of the object matching up. If my color data is pure SHO, I would create a PseudoLuminance from the SHO masters but not use actual Luminance data.
If I have RGB and SHO data in the color, and I want to use L data too, I would create my RGB+SHO color mix first. Then I would create a SuperLuminance and subsequently add the SHO data to the SuperLum in pixelmath using some multipliers depending on the relative strengths of the channels.
For example, RGB/K: SuperLum*.5 + H*.2 + O*.15 + S*.15
I would then use that result as the Luminance channel for my RGBSHO color data.
You mentioned a difference in sharpness. Why would there be a difference in sharpness between the L and SHO data? Unless the seeing was quite different on the nights you shot your L and SHO they should have pretty close FWHM’s.
Kevin
Arny avatar
Kevin Morefield · Sep 15, 2025 at 04:12 PM
Hi Kevin,
What I am trying to do is to use the maximum of exposures taken to increase SNR and detail - so all LRGBSHO channels I have taken which I would call a super luminance of all channels taken.
As you point out, you have less detail in the L channel than in the SHO channels, so working with a synthetic luminance made from SHO would fix that, but I would not see the benefits of the SNR increase of the longer super luminace exposure.
So far I have not found a way, that my SHO looses detail when combining with any kind of LRGBSHO or LSHO super luminance … and if I understand Andrea right, working with a synthetic SHO luminance would not add benefit either.
So is there a way to benefit from all LRGBSHO channel integration time?
Arny
OK, maybe I understand better what you are after. If you want to get all the benefits of the higher SNR of Superluminance but retain all of the narrowband structures you need to add continuum subtracted narrowband masters to your SuperLuminance. You do that in linear space with starless, continuum subtracted Narrowband masters.
I outlined almost that exact set of steps in my last image here: https://app.astrobin.com/u/morefield?i=a9abdt#gallery
The only difference is that I didn’t use Luminance filter data. So in step 8 where I used extracted L from the RGB master, you would instead use ImageIntegration to create a SuperLuminance from the LRGB masters.
Does that sound like what you are looking for?
Helpful Insightful Respectful Concise Engaging Supportive
Arny avatar
That is exactly what I am looking for - thanks for getting my point and sharing details of your processing, Kevin!
I will sure try it out! Seems like it works like doing RGB + Ha, only you do it for all SHO channels.
So just to be sure: is it only possible down that route to enhance the RGB image with SHO?
or can the other way work as well enhancing the SHO with Luminance?
Arny
Arny · Sep 16, 2025, 05:10 AM
Arny
Not sure if I follow the question but you can add the cont. subtracted SHO to the RGB and to the Luminance. In fact you should add the SHO to both.
