Handy Google Sheet for FoV, Seeing, FWHM, Resolution / Image Scale, Imaging/Guiding ratio, Power capacity, etc
5 replies249 views
Mathieu avatar
Hello,
The past days I have constructed a Google Sheet to help me combine the right imaging camera, guiding camera, imaging scope and guiding scope, plus the necessary power required for the whole setup.
This Google sheet displays some metrics such as: imaging scale (resolution), pixel size, imaging/guiding ratio, field of view, etc, depending on the parameters entered: camera/scope combination, binning, seeing, etc. You can also quickly select the equipment to have a rough idea of the power required and number of hours you will get.
PREVIEW:
There is an online read-only version here
You can see a preview in the PDF attached
CONTRIBUTE:
Anybody can add its own cameras, scopes, and build their own combinations etc.
>>> An online editable version is available here <<<
Suggestions are also welcomed and can be listed in the "SUGGESTIONS" sheet, but feel free to edit / add new sheets, etc.
BACKUP / OWN IT:
You can do a File > Make a copy to copy the sheet in your own Google Drive folder and use it by your own. Content is not subject to copyright, feel free to copy, edit, and use!
HELP PREVIEW:
1 Select your seeing GO THERE
2 Enter your cameras GO THERE
You can enter many cameras and check the ones you own - they will be highlighted everywhere
=> You will see the recommended focal length for your resolution range
3 Enter your scopes GO THERE
You can enter many scopes and check the ones you own - they will be highlighted everywhere
=> You will see the recommended camera pixel size for your resolution range
4 Enter your combinations of cameras and scopes for imaging and guiding GO THERE
=> You will see the resolution of the imaging and guiding setup
=> You will see the approximate maximum seeing (FWHM) supported by such resolution
=> You will see the field of view of the imaging and guiding setup
=> You will see the imaging / guiding ratio
Combinations that are within the range of your selected resolution at STEP 1 will be highlighted in green.
The imaging / guiding ratio will be highlighted with a color scale ranging from green (1:1) - yellow (1:5) and red (1:10).
A good ratio is close to 1:1
5 Enter your equipment requiring power GO THERE
5.1. Enter your equipment with the required voltage and maximum amperage consumption
5.2. Enter your batteries with their capacity
5.3. Select the equipment you will use for a session
=> You will see the total hourly power spent
=> You will see how many hours / minutes you will run on a battery at 90% and 80% of its capacity
Battery only have at best a capacity of 90% which can go down to 70-80% on a colder night
6 Look at potential target objects GO THERE
Enter the list of interesting targets with their field of view
The field of view value is chosen so that the target can be seen fully in the frame, or if too small, in an acceptable way
You can then easily see what are the suitable targets based on the computed field of view in STEP 4
DISCLAIMER:
I am quite a newbie, this sheet helps me keep organized, but some mistakes can still be there, and obviously I hope you will be kind enough to fix them :-)
About: resolution, under-sampling and over-sampling:
We can find a lot of valid, different opinions about the right resolution to stick into.All depend on your use case and seeing.So the way I have built this sheet, this is up to you to choose the seeing you have in the PARAMETERS sheet, or select a "recommended" range that gives an acceptable resolution range for you. For example, from my readings, Atik recommends a range between 1-2.5 ″/px, Craig Stark around 0.65 - 3.50 ″/px, consensus is around 1-2 ″/px without questioning, etc. We can also see a lot of famous photographers under-sampling up to 4-5 ″/px, and depending on the scope (250 mm vs 1000 mm for example), the effect of under-sampling will be different. Under-sampling when using a wide scope / Dslr camera is acceptable since the Fov is very large.
I hope this sheet will help also some people there ;-)
Clear skies!
Salvatore Iovene avatar
@Mathieu,
fantastic job!
I'd be interested in working on integrating this into a nice and polished tool with a nice UI within AstroBin.
This will fit very nice with the extensive and detailed equipment database that we're building.
Can we be in touch about this next month?
Salvatore
Mathieu avatar
Yes, why not!
The Google sheet is free of use / modifications and the formulas are widely available so if it can be used as an inspiration to improve AstroBin I would be happy ;-)
John Hayes avatar
Mathieu,
You've clearly put a lot of work into this project and it looks very nice.  I agree with Salvatore that it might be a nice tool to integrate into AB.  However, I can see a number of minor things that could be improved but I'll start with just one thing that stands out.  Be careful not to mix up the idea of "resolution" with "image scale".  Those are two completely different concepts and they do not mean the same thing.  Image scale is a geometric quantity that relates to the sampling rate either in image space or in object space (the sky).   Resolution is a term that specifically describes the ability of an imaging system to separate two point sources and it involves the optical system, the sensor, and the effects of the atmosphere.
I didn't dig deep enough to see how you are handling sampling so I'll have to spend some more time to see if I agree with the way that you've done it.  This is a topic that should be carefully implemented–and I've noticed that a lot of similar calculators often don't get it right.  I've gotta run but I'll try to find some time later today to give you some feedback.
Mathieu avatar
John Hayes:
Thank you John for the constructive feedback!
The Google Sheet only shows the resolution right now and is computed based on the FoV (about the same formula David Campbell is using at www.12dstring.me.uk). I didn't use the approximated formula (Pixel Size / Focal Length * 206.265), but sincerely, I probably should because it gives about the same results, and considering anyway how the resolution numbers are used, I don't see the value in being exactly right ?
The Google Sheet right now does not refer anywhere to the image scale, though, it is missing.
Respectful
John Hayes avatar
Mathieu:
John Hayes:
Ok, this simple computation leads to another suggestion.  Be very careful about units.  Image scale in image space is simply given by:  arctan(Pixel Size/Focal Length).  If you want image scale in units of arc-seconds per pixel, you compute 3600 ["/deg]*arctan(pixel size [mm]/focal length [mm]), assuming that arctan is computed in degrees.  Since these are very small angles, the image scale can be (very closely) approximated as (pixel size [mm]/focal length [mm]) * (180 [deg]/pi [radians]) * 3600 ["/deg].  In that case, the scale factor is 206,265 ["/rad].  If you want the user to input the pixel size in units of microns and the focal length in mm, the scale factor becomes 206.265 [arcsec-mm/micron].  So it is very important to specify for this computation the units for both pixel size and the focal length.
-John
Sub selection for final images
Hi all, With weather being pretty bad right now, I have been looking at my data and have had a look at the quality of my subs. I use APP for stacking which provides some useful information, I now take the process to normalisation where I then decide ...
Includes FWHM metrics relevant to subframe quality assessment.
Aug 27, 2020
Which scope for galaxy imaging? 8" f/4 Newton, RC8, or 5" Triplet?
Hi everyone, long post incoming - excuse my ramblings - after I finally moved to a place with a secluded and safe roof terrace where I have enough space to put up two rigs, I'll plan to add another rig for smaller Targets next to my CEM25P with a...
Discusses scope selection criteria relevant to imaging setup optimization.
Apr 23, 2023
Please help: comparing two fl, f ratios, pixel scale, etc
I need help understanding something. I often hear experienced imagers say they want long focal length scopes to do images of DSOs. They say it "increases resolution of extended objects". I am looking at adding a focal reducer to my CDK 14 Z...
Directly addresses pixel scale and focal length comparisons for imaging.
Oct 15, 2023
"High resolution" with the Samyang 135
Since I bought my Samy 10 months ago I've been amazed by the quality of that little lens, all the more so given its ~400 euros price tag. It is so sharp that its full potential can only be exploited fully with small pixels detectors (~3-4 microns...
Covers FWHM, resolution, and imaging parameters author is actively discussing.
Jan 27, 2020
Hello everybody
Hello everybody, my name is Francesco, from Italy. I have had a return of flame for astronomy, after the seed that was seeded by my father when I was a child. I have organized my first set-up for astronomy and astrophotography with a Skywatcher 80 ED...
Google Sheet tool helpful for optimizing your imaging and guiding setup.
Aug 23, 2020
