GPT5 minimalist work flow in PixInsight.
9 replies330 views
Himanshu Pandey avatar
I asked GPT 5 for a minimalist workflow to process a dual narrowband OSC image in PixInsight. I asked it to consider all the freely available 3rd party plug ins as well native PI processes and to recommend the best process for each step. I constrained it to avoid separating/recombining stars as well use of masks, just a very simple direct process to a final image. I understand how much power PI has under the hood and this is just my way of diving in.
Below is what it gave me, what do you think?
  1. DynamicCrop
    • Remove stacking artifacts and edge gradients.
  2. Gradient Removal
    • GraXpert (Astro model, Medium strength)
      or ABE (Degree 2–3, Subtraction) if you want native only.
  3. Linear Noise Reduction
    • MURE Denoise (if gain/RN known)
      or MLT (5 layers, conservative thresholds) if not.
  4. Channel Extraction & OIII Mix
    • Extract R = Ha, G/B = OIII.
    • PixelMath: OIII = 0.7*G + 0.3*B (adjust weights by SNR).
  5. LinearFit
    • Reference = Ha, apply to OIII.
  6. HOO Combine (Normalized)
    • PixelMath:
      Hn = Ha/(Ha+OIII+1e-6); On = OIII/(Ha+OIII+1e-6); R: Hn G: 0.2*Hn + 0.8*On B: On
  7. BackgroundNeutralization
    • Small preview on true background.
  8. Stretch
    • GHS (2 passes) → HT for fine black/midpoint placement.
  9. Local Contrast
    • LHE (Kernel ~64, Amount 0.3) global.
  10. Color Tuning
    • Curves (global saturation/hue).
    • SCNR (Green, 0.25) only if needed.
    • CorrectMagentaStars (global).
Quinn Groessl avatar
“minimalist” I’d say it failed like it normally does with such tasks.
Quinn Groessl · Sep 10, 2025, 09:38 PM
You’d get a kick out of its 1st response…literally twice as long as what I posted….
Oscar H. avatar
I disagree with the linear denoise (I dont think anyone really uses Mure, and MLT/MMT is hard to deal with without stripping away detail; just use NXT, or DeepSNR - which is free), and also the local contrast part (simply applying LHE without masks is horrible advice), also what I assume CorrectMagentaStars does, can be easily done with SCNR Green on the image, inverted.
EDIT: Also, I cant understand the pixelmath, but it honestly doesnt look good
I asked it again with a slightly different prompt and got the following which is inline with how I started this work in Siril.
Here’s the same minimalist, mask‑free, star‑intact OSC dual‑narrowband workflow for Bortle 8.6 skies, restated as plain text so you can copy and paste without table formatting.
1. Linear Preparation
1.1 DynamicCrop — Remove stacking edges. Define crop once on a reference frame and save as a process icon for reuse.
1.2 AutomaticBackgroundExtractor (ABE) — Remove light pollution gradients. Use function degree 3–4, correction mode set to Subtraction, and replace the target image.
1.3 NBColourExtraction (Bill Blanshan script) — Extract Ha and OIII from the OSC stack. Set the correct CFA pattern and filter wavelengths (Ha = 656.3 nm, OIII = 500.7 nm).
1.4 MultiscaleLinearTransform (MLT) — Linear noise reduction. Use 3–4 layers with low thresholds (L1 = 2.5σ, L2 = 1.5σ, L3 = 1.0σ) and an amount of 0.6–0.8.
2. HOO Combination
2.1 PixelMath — Combine Ha and OIII into an HOO composite:
R: Ha
G: 0.85*OIII + 0.15*Ha
B: OIII
Create a new image in 32‑bit float, linear.
2.2 SPCC (Spectrophotometric Color Calibration) — Use narrowband mode with correct filter wavelengths. Enable background neutralization.
3. Stretching
3.1 GeneralizedHyperbolicStretch (GHS) — Global stretch with stretch factor ~3–4, symmetry point ~0.25–0.3, and highlight protection enabled.
3.2 CurvesTransformation — Apply a mild S‑curve in the L channel to boost contrast.
4. Non‑Linear Refinement
4.1 CurvesTransformation — Adjust hue for the desired HOO palette and apply a mild global saturation boost.
4.2 BlurXTerminator (if available) or Deconvolution — Apply global sharpening with low iterations to avoid ringing.
4.3 MultiscaleMedianTransform (MMT) — Non‑linear noise reduction. Use layers 1–3, amount 0.4–0.5, with low thresholds.
4.4 MorphologicalTransformation (optional) — Reduce star sizes without masks. Use erosion with amount 0.15–0.20, 1–2 iterations, and a circular structuring element size 3.
5. Finalization
5.1 CurvesTransformation — Apply a small global saturation boost in the S channel for final color pop.
5.2 ProcessContainer — Save all steps with fixed parameters for one‑click reproducibility.
Shinpah avatar
It spit out mostly a bunch of gibberish (which is typical).
As far as I can tell "NBColourExtraction (Bill Blanshan script)" doesn't exist. Perhaps it means NB Normalization?
There are numerous redundancies, particularly the color calibration for mono being duplicated across NB normalization, and the Pixelmath, and SPCC, and the Nonlinear Hue adjustment. The deconvolution step explicitly is misplaced.
I wouldn't trust any of the specific numerical values it assigned as a setting for any pixinsight process. That's really the meat of processing and naturally has some trial and error.
Helpful Insightful
Gilmour Dickson avatar
What do I think? I think there is a rather odd irony that you come to ask a forum of real people their opinion of the results from you asking AI for a processing workflow. Why don’t you skip all the AI stuff and just ask real people right from the beginning? I see more and more posts like this here and on cloudy nights and each and every time it leaves me scratching my head.
Stjepan Prugovečki avatar
Everyone has his/her own processing flows and tips and tricks. One thing in your processing flow is by my opinion very doubtful : Deconvolution (either “classical” or AI like BXT) being done AFTER noise reduction. This does not make much sense…
Stjepan Prugovečki · Sep 11, 2025, 08:48 AM
Thank you for using your time to comment constructively.
Rate my Mosaic
Hello everybody, so im kinda new-ish to mosaics, I have done a couple of them (I think this one is my 5th). I would like to know on what I could improve on. (this is OSC, but I bought a mono camera with chroma filters so tips for mono workflows are g...
PixInsight workflow discussion relevant to author's processing pipeline.
Jul 11, 2024
Another useful ChatGPT use: Compute RA and DEC offset for a comet image
With the short window we have for Comet C/2025 A6 Lemmon right now, I don’t have time to fiddle with trying to frame the comet in such a way that the comet nucleus is on the corner and the tail runs diagonally across the frame so I can get as much co...
Author used ChatGPT for astronomy calculations; similar AI workflow discussion relevant.
Nov 9, 2025
