Best way to combine Ha OIII SII with LRGB
4 replies626 views
Andy Wray avatar
I'm new on my narrowband journey and am looking for guidance on how best to combine the narrowband captures with LRGB to maintain star colour and keep a natural look to the images.  I've only taken a handful of narrowband images so far as I only started using a mono camera and filters at the beginning of November and clouds have been everywhere this month.  My only real attempt is:
HaOIIILRGB Crescent Nebula
Any thoughts/tutorials that you think would help would be greatly appreciated.
N.B.  I'm comfortable with using PixelMath in Pixinsight to do some of this stuff, but I'm not convinced by some of the formulas people are suggesting on YouTube etc..For example:  the usual ((Ha*Redbandwidth)-(Red*HaBandwidth))/(RedBandwidth-HaBandwidth)  doesn't seem to take into account the fact that Red subs are typically much shorter than Ha subs.  I may be missing something here.
The easiest way is to use the NBRGBCombination script in PI. Use the maximum bandwidth (200 nm) for best results in the RGB section of the dialog window. Fill-in the other sections and you're done. Sometimes the script might cut off the low end of the histogram (rare event but did happen) in which case you need to use the LinearFit process between R and Ha, G and OIII and finally between B and OIII. Use PixelMath to combine the fitted Ha and OIII frames to R, G and B. Note  that the fitted OIII frames are different (potentially) when G or B are used as reference frames. As for SII, add it to Ha and you're done. The modified R+Ha, G+OIII and B+OIII can then be used as normal in RGB composition.
matthew.maclean avatar
PixInsight does have a script called NBRGBCombination (script > utilities). It worked reasonably well for me for Ha overlay on M33. For the galaxy, I then also applied PhotometricColorCalibration to help insure a somewhat natural result. If you are looking specifically to apply RGB stars to an otherwise narrowband emission nebula, a common approach is to use the Starnet++ process to remove the narrowband stars and blend the RGB star layer back in as an overlay.
Well Written Helpful Concise
Andy Wray avatar
Andrea,  thanks for all the detailed comments.  I followed all of your comments until I got to the bit above ... what exactly are you hinting at here?  I have been varying the amount I apply the OIII to the blue and green channels, but I've been making up the factors myself;  I'm not sure if there is a more empirical way of doing it?
Andy,
When I said the above I meant that the process of applying LinearFit is to renormalize the OIII (or Ha) frame so that it has the same mean background and background distribution of the reference frame, say G (or B or R for the Ha frame). Once this is done the fitted OIII frame is numerically different from the original OIII , not only bacause of the LinerFit process has been applied to it but also because the reference frames (either G or B) are different, even more so if such frames are coming as part of a RGB/LRGB acquisition technique. Once this is done then you add them up together and rescale the result in PixelMath, e.g., G+(LinearFitted)OIII. As simple as that.
[RCC] Heart nebula. First time looking for feedback!
So I've always been more of a lurker of forums than interacting, but I've enjoyed where the astrophotography journey has taken me and would love to know more about how to do more with my images and such. Going to do an info dump below on the ...
First narrowband attempt feedback relevant to combining narrowband with LRGB.
Oct 9, 2023
Imaging dark/reflection nebulae Q's
Howdy all. I'm wondering what the best process is for imaging non-emission nebulae with narrowband, where they are in proximity to emission nebulae. Is it lots of exposure time for LRGB? LRGB for nebulae which would blow out stars and then take s...
Directly addresses narrowband imaging techniques and processing strategies.
Jul 29, 2023
