New equation locks Hubble constant to light speed value
3 replies139 views
David Hine avatar
Ho is now locked down or "fixed" to light speed, C by this simple Ho equation worked in the old algebra style of Maxwell:-
2 x oneMpc x C, divided by Pi to the power of 21 = 71 k/s/Mpc
Measuring Ho gives the "ballpark" value of Ho, and now we have an Ho equation that now locks Ho to light speed, C, which
has to be much more precise.
Note that in in the numerator, distance is multiplied by speed, and that is NOT an error in this situation, as the "distance squared" does not affect the numerical value of the Ho redshift by "spreading out" (as any light source does) when viewing that redshift along just one dimension only.
In this equation, directly input the values below:-
oneMPC is 3260000 light years
C is 299792.458 k/s
Pi is 3.142..........
With very kind regards, David Hine.
Email:- dhine2999@yahoo.com
David Hine avatar
Hi I will add another new equation that compliments the first equation, allowing easily calculation of the Hubble Horizon Distance;-
Hubble Constant (Ho) fixed to light speed, C and calculated as 71 k/s/Mpc
My name is David Hine, and here is an interesting Hubble Constant equation that "fixes" Ho to local light speed, C.
Ho is now "fixed" to local light speed, C by this simple Ho equation worked in the old algebra style of Maxwell:-
2 x oneMpc x C, divided by Pi to the power of 21 = 70.9449 k/s/Mpc
C (local) is 299792.458 k/s
Astronomers measuring Ho give the "ballpark" values of Ho, and now we have an Ho equation that "fixes" Ho to
local light speed, C, which has to be much more precise.
Note:- In the numerator, distance (Mpc) is multiplied by speed (k/s), and that is NOT an error in this situation, as the "distance squared" does not affect the numerical value of the Ho redshift by
"spreading out" (as any light source does) when viewing that redshift for Ho along just
one dimension only.
The dimensionless denominator Pi^21 sets the scales of this Ho equation correctly into the Dynamic Aether framework.
The Dynamic Aether Framework is not the static aether that the Michleson-Morley experiment could not detect, but
the Dynamic Aether that Faraday knew caused electrical "reluctance", and that Maxwell used as the basis for his
electric and magnetic "inertia" constants, and used in his Aether equations to calculate light speed. C..
Hubble Constant (Ho) Hubble Horizon Distance light years calculated from Ho of 70.9449 k/s/Mpc.
oneMpc X C, divided by Ho, and then divided by one billion = 13.7758 billion light Years
oneMpc is 3260000 light years
Ho is 70.9449 k/s/Mpc
one billion is 1,000,000,000 used to give the answer in convenient units of
billions of light years.
Note:- This Hubble Horizon Distance equation prevents falsifying the terminology of
declaring light years as years only.
The "Hubble Tension Issue"
Note:- In the "Dynamic Aether Framework" of the Ho calculating equation in which Ho is "fixed" numerically to C,
the "Hubble Tension issue" is caused by the "DISTANT LOCAL VALUE" of C in the observed space regions being
directly affected by the presence of huge galaxies, black holes. or void areas, RELATIVE to the observer.
Download all attachments as a zip file
Salvatore Iovene avatar
Hi Dave,
AstroBin supports Latex syntax. You can edit your post so that equations are formatted properly if you want!
Well Written Concise
David Hine avatar
The proper system of doing predictive algebra is to maintian the original units in the equations, and give the answers in the original units. To use the "SI" system for algebra creates errors and severe loss of units information. that then leads to wrong conclusions that wreck truthful cosmology science. I would say that is now the biggest problem that exists for theoretical cosmology these days. I will NEVER use the "SI" system of maths for anything "algebra maths predictive". Simples
