GHS stretching haze around stars while enhancing IFN in Deer Lick Group
3 replies145 views
Rabeea Alkuwari avatar
I’d like to ask about a problem that I was dealing with for quite a while though it got worse on the latest data im trying to assemble of the deer lick group. while trying to enhance IFN around the group, GHS seems to stretch lots of “haze” around stars as well. I used to deal with this problem around very bright stars however now its all over the place. I’d like to know what might’ve caused this to get worse (is it just weather? maybe accumulation of dust on the front lens?) and how would I be able to clean it up without messing with the faint IFN im trying to show. I’ll attach my L stacked and processed data for reference📷 L.png
Usually i stretch post start removal using StarXterminator
Mikołaj Wadowski avatar
These halos look to me like you included data with high clouds in your stack or, like you suggested, shot with dirty front lens. Blink your subs to check if none have any clouds in them.
However, I still find GHS to make the stars more hazey/soft, which likely only adds to the issue you’re having. I recommend stretching the stars with a simple HT midtones adjustment.
Were these halos visible in the starless image, or did they only show up when you added the stars back after stretching?
Helpful Insightful Respectful Concise Engaging Supportive
You had high cirrus clouds interfering with the imaging so culling those frames affected should give a much cleaner starting point. I don't think dust can do that. If there is a clean separation between star halos and IFN there are ways to reduce those halos but it requires a lot of manual handling.
Helpful Insightful Concise
Have you blinked your frames? If it’s high altitude clouds or haze it should be apparent as you flip though the “movie”. You could effectively do the same thing by looking at star counts assuming the haze was variable through the session.
Diagnostic help, please
Hello, I have searched many sites looking for similarities regarding a worsening issue I have been fighting for some time. I hope that posting here and attaching some photos will help with the diagnosis. Essentially, my stacked light frames using the...
Worsening imaging issue similar to yours; diagnostic help may apply.
Oct 19, 2025
EZ Soft Stretch not working
Hi all. I updated pixinsight today to the latest version and all of a sudden ez soft stretch no longer work properly and so does graxpert. Wondering if anyone else has had similar issues and how you fixed it. I have attached 2 files to see what im ta...
GHS stretching issues in PixInsight; directly relevant to your soft stretch problem.
Apr 24, 2024
Processing techniques for LDN 1089: balancing faint dust and bright stars
I have recently published a post about the techniques that I used to process my image of LDN 1089 (https://app.astrobin.com/i/gfwv5v). Unlike my two previous posts, this is not a full step-by-step walkthrough, but it rather focuses on the challenges ...
Addresses haze artifacts around bright stars, directly applicable to LDN 1089 processing challenges.
Aug 11, 2025
Help with dust on QHY600M sensor after cleaning attempt
Seeking advice regarding dust on QHY600M sensor and sensor window. This is one of those “The enemy of good is better” stories. I am truly embarrassed and feeling very sad. Several days ago I noticed ice crystals on my QHY600M sensor window. So I used...
Dust on optical surfaces causes haze; directly addresses your concern.
Oct 8, 2025
