OCAL 3.0 pro max VS OCAL 4.0
8 replies378 views
Gabriel avatar
I’m currently looking for a good tool to improve the collimation of my newtonian telescope, and so I found the well known OCAL collimator.
I thought the last one was the 3.0 pro max but no, the 4.0 is now out. It seems to have better resolution but a smaller aperture.
My question is, why is the 4.0 100€ cheaper than the 3.0 pro max ??
if you have any advice about this or an advice for which one should I buy, I’m taking !
thanks in advance !
Gabriel
An autocollimator, if it can be found.
Christian Bennich avatar
I cannot speak to why the 4 is cheaper, but I’m using the 3 Max, and very happy with it.
Easy and precise.
Take a look at MetaGuide’s collimation feature, it wont cost you a dime…
Gabriel avatar
Tony Gondola · Aug 29, 2025, 11:59 PM
Yes but it doesn't give an answer to my question :(
Gabriel avatar
Christian Bennich · Aug 29, 2025, 04:46 PM
Easy and precise.
Some told me Ocal is not selling enough 3.0 so they decided to lower the price of the 4.0 but.. Hum not convinced 🙄
Deepan Vishal avatar
There’s a page on OCALs website showing differences between these cameras. It is vague though.
I am new to newtonians, using the Ocal 3.0 max and I am very happy with the results. (My setup is F2.8 and very sensitive to collimation.)
When I purchased them, there were not many videos on how to use them and it took time to figure out how to use it to get perfect results.
Just an extra piece of advice, Ocal is just a digital cheshire and will not solve all the problems related to collimation. If you have a good understanding of the collimation, you’ll find it easier to collimate with it. .
c_future avatar
Hi.
I will Post a comparison image between 3max and V4 this Saturday.
I will try it on a 10” newt F4 with a starizona Nexus reducer installed which makes focusing challenging and also I would be happy about the extra resolution. (But it worked with the 3max)
c_future avatar
Ocal 3 MAX:
https://youtu.be/W3dO2-fhnsA
Ocal 4:
https://youtu.be/WwsQAWDBW_c
verdict: the sensor resolution when zoomed in and noise is much much better on the OCAL 4.
This would allow much finer positioning of the centric circles and collimation.
BUT - my example has a quite severe sensor tilt on focus.
you can see that I dont have to go down to 0 to get the main mirrors center mark into focus with the ocal 4. but way before that, the image is shifting quite a lot.
With the ocal 3 max i need to go down to 0 but the image stays stable all the way.
OCAL3.0 (or 3.0 Max) and RC Telescopes
Does anyone have experience collimating an RC 8" scope using the OCAL collimator? I think it should work well, it definitely works well with an SCT. Thanks, Jerry
OCAL collimator comparison directly relevant to author's RC scope collimation question.
Mar 20, 2024
Do you rather use Reflector or Refractors and why?
So I'm currently on the verge of buying a new Telescope budget isn't very hight at about 1000 - 1500 dollars. I've been very unsure about which one would suit me better. I currently have a WO Z61 with a fieldflattener at 360mm and a very ...
Addresses collimation issues relevant to author's problematic 8" Newtonian telescope.
Jan 31, 2024
Takahashi collimation telescope VS TSCOLLIT
Hello folks, There is a lot of information circulating about these two tools; the Tak side is legendary it seems and the TS side is brand new ( which does not in any way mean it is less). My question is: which one are you using and how successful are...
Discusses collimation tools comparison, relevant to author's tool evaluation question.
Jun 1, 2025
