Mount axes swapped?
2 replies78 views
Christoph B avatar
I am trying to get started with this mount and I am getting more and more the impression that my axes are swapped, meaning that DEC changes actually cause RA changes and vice versa. This happens during three point alignment, where the RA axis should be rotating between frames but in fact DEC is rotating, leading to completely useless alignment information.
I have tried this on an ASIAir as well as NINA, using different connection models. In all cases, adjusting the scope along the E/W axis changes the DEC axis but I would expect it to change the RA axis.
Has anyone experienced that? Also helpful: Can you help me confirm the axis swap: Which axis moves when you press the „slew right“ button on the SynScan App?
Thanks a lot
Christoph B avatar
Just to sum this up. I ended up sending the mount in for repairs. It seems that the axes were indeed swapped on the hardware side.
Well Written Concise
Andrew avatar
Wow really goes to show skywatcher has 0 quality control lol
-somewhat joking
Polar align EQM-35, asiair problem
Hey everyone, after several attempts to figure out why I keep getting star trails and what's wrong with my alignment, I’ve decided to ask for help here. I’m trying to polar align my EQM-35 mount using ASIAIR. First, I manually aligned it using th...
Mount axes swapped could explain RA/DEC errors during polar alignment checks.
Dec 21, 2024
Problems setting home position and strange behaviour using EQMod
Hi all, maybe there is someone out there who can help me with a strange problem I have with EQMod. I use 3 permanent setups. On two of them all is working fine. But on the third setup, I got some weird behaviour using EQMod. It all started several da...
Mount axes swapped? — DEC value anomaly suggests possible axis configuration issue.
Aug 7, 2024
CQ350 Tracking Issues
Have recently bought a CQ350 mount for use with my GSO RC12 and I having an issue with the mount. I wonder if anyone out there can help with advice and/or experience. This is the 1) When the RA drive clutch [not the best design in the world] is locke...
Not relevant - Axes swap issue differs from RA play and tracking jump problems.
Mar 8, 2024
Slew rate does not make sense
Hi, I have a problem where NINA (or possibly SynScan Pro or the mount) is slewing way faster in the RA axis than it thinks it is. This leads to the mount overshooting substantially and I have no idea how to fix this. The following is what I can see:P...
Axis control issues could relate to slew rate problems affecting alignment accuracy.
Oct 13, 2025
CEM40EC Handset: "Unknown Position" - What does it mean?
I may be a little paranoid after suffering a tripod collision due to a known (but not to me) software compatibility issue between the ASIAIR and the CEM40 series of mounts. But I just noticed that as soon as I begin to slew after setting the mount ze...
Mount communication/positioning errors may cause axis confusion during alignment procedures.
Jan 28, 2026
