Check for flexture in the imaging train. One culprit could be the Canon to T2 adapter. If it is wiggly, you will see this. Another one is differential flexture between the guide train and the imaging train. Or even the guide train being out of focus. If the guide train is seeing dumbbell shaped stars, it cloud do this, oscillate the imaging train. PHD2 logs will show this with constant corrections on both sides of 0.
Another one is the worm gears in the GTi. How much are they moving under load? There are 2 screws to tighten them. I had to tighten mine till my GTi was stiff then backed off 1/8th to 1/4th turn at a time till it was not wiggly but moving smoothly. This is an unguided experiment with 30s subs with an Askar SQA70 and a full frame Nikon, after cleaning and tightening the worm gears: https://app.astrobin.com/u/Astro%C3%85mazer?i=6vwdwg
Also what length of subs, what percentage of subs show this?
Edit:
My debugging recommendations:
Check without guiding, tracking only. 30s subs. With good polar alignment, it's possible to get round stars with your setup. If this happens without guiding, then it's the imaging train (flexture in adapters, cables dragging etc.) or the mount is loose.
If it does not, it is guiding. Differential flexture or badly focused guide train. Or over aggressive guide settings causing oscillations.
