ASIAIR Mini Amp Problem
5 replies104 views
Johannes Maximilian Möslein avatar
Hello,
I'm having trouble with my ASIAIR Mini concerning power supply, especially Amps.
Recently it's behaving very strange, and the internal measurements show 12V, but only 0.1A.
After seeing that, I tried multiple PSUs (2 official ZWO 12V5A, 1 third party), different cables and sockets, connected/disconnected every USB/12V device but it still shows just 0.1-0.2A.
If the AIR really is done, it probably would be economically better to just get a new one instead of trying to repair it.
But before going down that path, I just wanted to ask if anyone has had similar problems and found a fix.
Thank you,
Johannes
Médéric Hébert avatar
I have no experience with the ASIAIR, but the power supply should work like any other: it gives what the device requires. So if it’s not under load, it’s normal to only send low amperage. The rated 5A isn’t what the power supply deliver all the time, it’s the upper limit of what it can supply (may be 5A peak and not 5A continous, but that’s beside the point).
If you are using a cooled cam, try cranking the cooler power to see if the amp reading increase or not.
I’m heading to bed so sorry if I miss-understood your issue.
StefanL avatar
It could be that the numbers reported by the ASIair are wrong, but that the power is still delivered.
In that case, it is annoying, but not the end of life of the ASIair.  I would then just keep using it.
If the power is not delivered, then it is another matter of course.
Médéric Hébert · Aug 20, 2025, 08:41 AM
This is exactly right, that’s how electronics work. To actually measure amps being delivered you have to put the power supply under load (powering something) and measure amps in circuit. That way you can what the device is drawing from the PS.
You are right, it draws what it needs. I just think it should draw more, considering it's running and powering 4 USB Devices.
The main reason I suspect something is wrong, is because the AIR is behaving funky - messy guiding, buggy Go-To, bad connection, etc.
In the past that was always indication of bad power supply, mostly weak PSUs or broken cables.
I did reset the Firmware, but nothing changed.
I'll try running tests again once the rain disappears, maybe it will have calmed down by then and is back to being fine.
Thanks for all the answers.
Respectful
I guess the question would be, how are you measuring it. Is this an internal value being reported by the air or did you actually put a multimeter in circuit between the Air and the powersupply?
ZWO EAF and Guidescope Disconnects
I have the ASI2600 MC Pro and ASI183 MC Pro cameras on two different setups. Both are interfaced (power and connection) through ASIAIR+. I get intermittent disconnects of either my ZWO EAF and/or ZWOASI120mini camera when connected to either camera&#...
ASIAIR Mini power supply problems relevant to author's suspected power issue.
Jul 27, 2024
2600MC Pro disconnection issues
Hi all, Having an issue with disconnects every since getting a new 2600MC Pro. I am using an ASIAIR Plus and have had over a year of use with a DSLR without this issue ever occurring. This my 3rd night of using a new 2600MCP and on each night have ha...
Power supply issue with ASIAIR may relate to disconnect problems.
Nov 25, 2025
CEM70 Disconnects via USB
Hi All, I've been having a recent issue with my CEM70 dropping connections. I have the CEM70 connected via USB to a mini PC. It is powered by a 12v 5a adapter that is plugged into the wall. (via power brick) I've run this same config for abou...
Power supply amperage issues; relevant to CEM70 power adapter concerns.
Nov 26, 2023
Canon R5, ASIair Mini compatibility problem?
Hello, For the first time, I tried using my Canon R5 with my C8-N reflector on an AVX, with a Orion Deluxe Mini guidescope and asi120mm mini guide camera for guiding, all controlled by ASIair Mini. Here's all the failures I had before I gave up: ...
ASIAir Mini power supply problems match author's power station setup.
Dec 25, 2023
ASIAir mini 12V output ports
Hello, I just acquired the ASIAir mini for a second rig and can't figure out how to switch on the 2 output ports. The options aren't there when I hit the wifi icon on the app. I'm looking to power my dew heater. No issues with my ASIAir P...
ASIAir Mini power/amp issues; potentially related to output port problems.
Oct 22, 2024
