How to identify which images WBPP rejected during stacking?
1 reply92 views
Niels_L avatar
I ran Pixinsight WBPP and during the integration step a number of the images are rejected. Not an issue with that but how can one trace back afterwards which images have been rejected?
In this instance, I was stacking data from 2024 and 2025 and about 100 of the 600 lights were rejected during the integration step. I would like to know if these rejected lights are from a specific night or perhaps all the data from 2024. But I cannot find in the log files which files are rejected (or integrated) and what the reason was for rejection…
Niels.
Marcelof avatar
You should probably ask on the official PI forum, where more experienced users could help you.
https://pixinsight.com/forum/index.php
But first, I would open the log in a text editor and search for the words “rejected” or “bad frames.”
Well Written Concise
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
WBPP rejection issues during processing steps may relate to integration failures.
Sep 28, 2025
Stacking different resolution images in WBPP
Hi guys, I am taking images using a dual setup with DSLRs that produce different resolution images. The preprocessing is done in WBPP. Here are some screenshots showing my configuration: Post-Calibation tab: WBPP creates separate integrations for eac...
WBPP image rejection during stacking directly relates to integration workflow issues.
Oct 3, 2024
WBPP interactive frame selection: tracking included frames for Astrobin uploads
I used the new interactive mode for frame selection in WBPP and it works great. It is easy to see what should be rejected in your light frames and what to include. It saves the hassle of getting into SubFrameSelector and making a copy of the selected...
Traces which frames WBPP rejected; directly addresses author's missing frame selection data.
Feb 1, 2026
WBPP Weirdness.
Anyone seen anything like this before? 306 active files in an Integration but no master file generated???
Directly addresses tracking rejected images during WBPP integration step.
Jul 31, 2025
