LX200 GPS Coma
4 replies50 views
Aris Pope avatar
I recently acquired a LX200 GPS that i have deforked . The scope was well taken care of and. The optics are in very good condition. I've experienced some coma in the corners using my IMX 571 sensor. Stars in the center of the field or pinpoint. Has anyone else experienced this?  There isn't much documentation on the LX200 GPS online. I'm not using the corrector but plan to get the Starizona SCT corrector.. so far, Blur Xterminator eliminates the issue. But I would like to not have to rely on that if possible. A good friend of mine suggested it could be backspacing. But from what i understand without using corrector that would not be the issue..  Thank you very much.
That's pretty normal for a classical SCT, as the meade is.
Aris Pope avatar
Scott Dearinger avatar
just to add - your fine- the starizona will help immensely - i had a non edge had a c11 and the starizona sct corrector made it as good as an edge
Welcome to classic SCT land. With my old Meade, coma was there even with a 585 sensor at prime. The Starzona unit will fix you right up.
Help with Coma Corrector Backspacing
Hello, I recently finally purchased a coma corrector for my 6" f/5 Newtonian and I am having some serious difficulty getting the backspacing correct. Everywhere seems to say 55mm is the most common, but I have seen in a couple places that 75mm m...
LX200 GPS has coma issues; discusses coma corrector backspacing solutions.
Jul 9, 2024
Good coma corrector?
Hi guys! I’m just looking to improve my setup I currently own a Baader mpcc iii which works to a certain extent but its not really good enough to satisfy me. It doesnt seem to work at the distance mentioned in the manual so i ended up using extension...
Author seeks coma corrector alternatives; LX200 GPS coma experience may offer relevant insights.
Nov 11, 2023
Good Guiding scope combination with ASI174mm
Good day, So I just set my RASA back in my observatory. In the past I was using a ASI120mm with a Orion 130mm guide scope. But now I have a ASI174mm so my 130mm scope corner are are far from flat. And my guiding is the worst I have ever seen so far. ...
Discusses coma correction; relevant to flat field issues mentioned in post.
Jul 2, 2024
Poor starfield.
When i get pinpoint stars at the center of the field, i get such a poor covering of the stars in the corners, I am using a full frame sensor canon EOS R6. Imaging the Western Veil nebula for context. The image is a stack of 109 x 60 seconds, so there...
Discusses telescope optics quality; may address optical aberrations causing corner star issues.
Jul 27, 2024
Optimized Newtonian - Is it worth it?
There are a lot of ways I can think of that the current crop of Newtonian Astrographs can be improved. Lets restrict the conversation to apertures between 6 and 10 inches. 1.) Lowering the focal plane relative to the side of the tube (eliminate the f...
Not relevant; discusses Newtonian telescopes, not SCT/LX200 design.
Jul 28, 2025
