Using OAG with Optec Hercules and Epsilon 180
3 replies108 views
Deepan Vishal avatar
Anyone using the Optec hercules with OAG?
I am looking to use QHY OAG M pro and there isn't enough clearance. The helical focuser of the OAG interferes with the focuser.
Any had similar issue and found a work around for it?
Thanks,
Deepan
menelmacar avatar
Im putting together my E160 setup. what you need is the pegasus indigo oag without the heleical focuser. Trouble is that pegasus discontinued it but you may find a retailer that still has it. I added an 11mm m54 spacer to the corrector. The indigo requires the 4mm m68 to m54 adapter. 15mm is enough to get you clearance, I believe. Im using the qhy 600 short back focus camera without the tilt adapter. There is a large e160 thread on this forum that will be helpful. 56.2mm back focus fills quickly.
Thanks, That's useful information.
I just replaced my pegasus OAG. Never expected this to be this complicated.
menelmacar avatar
I was a bit lucky. I had a fault qhy600 that was replaced with one of the versions that allowed for only 7mm backfocus
here is what my setup looks like in back focus
qhy600sbfl. 7mm
ASG photon cage 3mm
ASG extra BF for tilt adjustment 1mm
qhy cfw 20mm
filters -1mm (for 3mm thick filters)
Pegasus oag 10mm
indigo M54F 4mm
M54 extender 11mm
total 55mm
This gives me 1.2 mm for adjustment
Adding a Rotator to a C11" EdgeHD with an OAG
I am thinking of adding a rotator to my C11 similar to my RedCat91 WIFD in which I use a Pegasus Falcon2 rotator. I know it is very difficult to see the C11 optical train with all the cables, but I would think the rotator should be installed in front...
OAG clearance issues relevant to rotator and optical train configuration planning.
Jun 13, 2025
Pegasus Astro Indigo OAG with Helical Focuser - Looking for Feedback from Owners
Hi all, If you are a user of the Pegasus Astro Indigo OAG with Helical Focuser, I have a question for you. I recently purchased this piece of equipment. It arrived in an old, dirty box without any foam. The OAG was in a small ziplock-style bag just l...
Discusses helical focuser on OAG; directly addresses similar clearance/interference issues.
19 days ago
PlayerOne 7x36mm EFW + Pegasus Indigo OAG
Hey folks. I have an Epsilon with an Optec Leo Focuser. I'm also using a 36mm/7x PlayerOne "Pheonix" EFW, but unfortunately there's not enough space between the focuser and EFW to use the PlayerOne OAG (the barrel of the OAG is too ...
Similar OAG clearance issue with Epsilon and Optec focuser setup.
Apr 12, 2025
