Help aiming at the ISS for imaging
1 reply116 views
Jaymz Bondurant avatar
Ok, friends. I need some help from anyone experienced in capturing the ISS. I've only caught it once and it was a solar transit. I used the ISS Transit Finder website and it nailed the location. This time, I'm going after the ISS itself and don't have a sun or moon to aim at. So, I'm using Stellarium to pinpoint where I need to aim. Here's the problem: The website shows an altitude of 79.2°. But Stellarium shows it at 76.9°. Now I don't know where to aim. I went to Google Maps and put a pin in my backyard to get my exact coordinates and copied and pasted them into both the website and Stellarium. So, the location isn't off. Who do I trust? I can't track the ISS so I only get one shot at this. Do I aim at 76° or 79°?
Edit: Disregard. The TLEs in Stellarium updated. They're still slightly off. But I'm closer to a solution. I could only edit the post and not delete.
It’s not a matter of knowing super accurately where to aim. You just need to know what azimuth, altitude and time when a pass begins from your location. Once you sight it visually, start your camera, Find it and keep in centered in your finder scope. You’ll usually you’ll get enough frames to work with that way. At least that’s one way I know it’s done. Much easier with a Dobsonian of course.
Concise
Need help for planetary processing
I do not have descent planetary photos to process so i'm looking for some that aren't process so i can process them and train myself. If you know a website where there are some or if you have some i would like to know, thank you.
ISS imaging involves planetary/celestial photography processing techniques and skills.
Mar 13, 2025
Transit finder help
Hello everyone, I'm trying to get an ISS transit pic, so.. naturally.. transit-finder is the place to figure out when it happens. Several times now, I've had transits listed on the website. You get excited, you buy more equipment, you test th...
Author seeks ISS imaging help; this directly addresses their transit photography goal.
Sep 6, 2024
