Unmounted Chroma Filter Orientation
3 replies151 views
John Binney avatar
I have recently purchased a set of unmounted Chroma filters. I have been trying to get clear instructions on which side of the filter faces the camera. The manufacturers say it doesn't matter. Cloudy Nights has several long discussions that agree it does matter but do not come to a clear conclusion. I appears most people suggest either the top of the text is towards the camera or the reflective side is towards the OTA. Others suggest try one way and if that doesn't work flip the filter to see if that gives a better result.
For a very expensive set of filters this is not satisfactory. If anyone from Chroma reads this can they please advise how they set up the bare filters in the filter ring for mounted filters.
Alternatively, if any reader is 100% sure which way the filters are fitted their advice would be much appreciated.
Rick Krejci avatar
My chromas are set up coated/shiny side toward the OTA and I’ve had no issues. You can tell the coated side by holding something like a cloth/qtip up close to the surface, there should be a single reflection with no gap between the object and reflection. That’s the general recommendation for most filters to minimize reflections bouncing between the sensor and filters.
Well Written Helpful Concise
Glenn Baxter avatar
Got an unmounted set at the start of the year and knew about the controversy so had to try both ways for myself, as I think you'll end up doing for peace of mind. Didn't make a difference for me.  "Bottom of the text to the sky" is the consensus so I just left them like that in the end. There seems to be plenty of examples where it does make a difference though. Perhaps it is scope or placement related.
The way I have always understood it is the side that looks like a mirror needs to be towards the sky. Reflective side out.
Seeking advice on Chroma LRGB filters for monochrome CCD cameras
I am planning to upgrade my LRGB filter set which is to be used with a monochrome CCD camera. I am considering the Chroma LRGB set of filters. I would very much appreciate hearing from owners of these filters about their experience with the filters a...
Chroma filter orientation and handling guidance directly relevant to purchase.
Dec 9, 2025
accessories for Zwo ASI IR-UV filter??
Hello. I have a Zwo ASI 294Mc Pro camera and a C 9.25. I bought a 2" IR/UV Cut filter from Zwo. But it doesn't fit inside any thread. Do I need any other accessories?
Unmounted filter orientation guidance relevant to filter installation problems.
Aug 29, 2023
How i know if my Touptek camera has ir/ar filter
hI there I would like to know if there is a way to know whether my ToupTek camera has an IR or AR filter, since the model doesn't specify it. It's the 533 Color ATR3. Any ideas
Discusses filter orientation and camera filters, directly relevant to filter identification.
May 1, 2025
Ha 5nm vs 3nm and the missing NII signal. Any examples?
I am looking at getting new 50mm narrowband filters. I was looking at Chroma Ha 5nm vs 3nm filters. Cost is not an issue, but I have read on multiple occasions that the 3nm filters will miss the NII bandpass details in certain planetary nebulae. Does...
Discusses Chroma filter handling, relevant to narrowband filter selection and use.
Sep 19, 2024
Focus issue or collimation issue?
I am setting up an AG Optical 12.5" iHW (f/3.9 Harmer Wynne design at roughly 1250mm focal length) and I am shooting with a QHY600 along with Chroma filters. I noticed that some nights I get these nice rings around stars on the RGB filters. Some...
Author uses Chroma filters; filter orientation affects optical performance and star appearance.
Aug 26, 2024
