Active Optics
Insane focal lengths 9 replies484 views
Daniel Petzen avatar
Hey all insane focal length people out there.
I just fitted my Starlight Xpress active optics, and wow!
I set aside an entire evening to get it to work, assuming all of the evening and probably days, weeks or months would pass before I got it to work.
After 1.5 hours of calibration (I got a new focuser, and dual telescope setup at the same time) I was up and running.
I normally get a good RMS at 0.5"-0.4", but with the OAG, I dropped to sub 0.3" for hours. I was sub 0.25" quite a few times.
If you're doing really long focal lengths, then I can't recommend it enough.
I had bad seeing yesterday, so it was pretty bad, but I hit it off straight away tonight:
Yesh, I know the AO is outside the limits I've set and I'm working on the "bump" settings.
Cheers, Dan
Bill Dirks avatar
Thanks for sharing. I've been curious about that device. What is the rest of your imaging train? What software are you using?
Hi Bill
I fiddled around quite a lot before I found a setup that worked for my C9.25 XLT. The first problem was that the outer diameter of the AO was too large to fit beside the ZWO focuser, so I had to get the Pegasus SCT focus cube. The focus cube is expensive, but I already love it.
The Pegasus focuser allowed be to attach the AO directly to the C9.25. I then have the Celestron OAG directly attached to the OA, and then some spacer before the ASI294MC (including filters):
In an enormous strike of luck, that image train just happened to be almost exactly 139mm, which is the native back focus for the C9.25 XLT.
I did some research into software. I contacted Innovation Foresight to see if SkyGuide support AO, but unfortunately not yet.
I was stuck with PHD2, so that was what I went with.
...and it worked amazingly well. I think the AO implementation in PHD2 is amazing. I just set up a new profile, said I had an AO and it just worked. I used the calibration assistant and it ran both the mount and the AO calibration, and then I was guiding using the AO.
I'm used to crappy software and hours upon hours of troubleshooting, but PHD2 has superb support for the Starlight Xpress AO.
It's not just sunshine and rainbows, though. Although I get amazing guiding, I've had run away condition when clouds have rolled in where PHD goes amok. I've also had times of bad seeing where I got better guiding without the AO.
I'm still working on both guiding algorithms and how the AO/Mount interact, but I'm well pleased so far.
Bill Dirks avatar
Interesting. Thanks for the photos. I haven't seen that belt drive focuser before.
Have you tried shorter guide exposures, 0.5s, 0.2s, 0.1s?
Well written
I hadn't seen the Pegasus belt driven focuser either, but as soon as I saw it I knew that was the solution. The Esatto would have worked as well, but that was way out of my price range.
I had one night with really good seeing where I experimented with exposure times. The sweet spot for me that night was 1 second. I dropped it to 0.5, but it made it jump around way too much.
The last night, with medium to bad seeing, I got the best results with 4 seconds exposure to my surprise.
I thought that an AO would shine with really short exposures, but I've not managed to get that to work yet.
That said, I've only experimented with the Hysteresis algorithm (on both axis) so far. It may be that the Z-Filter algorithm could handle shorter exposures.
Luxo avatar
Daniel Petzen:
Guiding RMS is one thing, but what are your stars like in raw subs ? It's hard to quantify I know, as star FWHM is extremely dependent on how oversaturated/exposed they are.
And I see you're using a Celestron...
On my mak I found most of my issues were related to less-than perfect focus; having installed an EAF recently the results are distinctly sharper without doing much else.
I've always had bad FWMH with my Celestron C9.25 XLT. I hadn't compared how the FWHM was affected by the OA, but I had a look just now.
The evening (Aug 13) with the good seeing and tracking (0.3") looked like this in the SubFrameSelector:
The previous session I had without the AO was on 23 July. The tracking was 0.42" the first two hours and 0.50" the second two hours:
Both sessions was with my ASI294MC with Optolong UV/IRCut filter, 240s exposures at 120 gain and and an offset of 5.
I'm very much in doubt that the AO can reduce the FWHM as much as this single comparison would hint at. I need more time, more sessions and more data to be sure.
I'm happy to do some experiments.
Dan
Bill McLaughlin avatar
Daniel Petzen · Aug 16, 2025, 11:37 AM
That is because the programmer (Andy Glasso) that did the AO part of PhD years back used the SX unit to develop it. I don’t think he is working on PhD anymore as far as I know and that part of it has not been changed (and does not need to be) in years.
Daniel Petzen · Aug 16, 2025, 09:59 PM
Don’t bother, it will not work very well and will cause more problems than it is worth. I have been using the SXAO on multiple scopes for over 10 years. I own two units (one spare) and currently use it on my CDK 14.
The original idea was for a high frequency AO for amateurs. That came from SBIG and Benoit Schillings way back in 1997 with a tip/tilt mirror system. I had one of those. One quickly discovers that there are three problems with high frequency use:
1) Bright enough guide stars for those short guide exposures are rare and multiple guide stars bright enough are nearly non-existent. There is a rather large benefit from using multiple guide stars and that is not worth giving up.
2) These systems can only correct for one order of atmospheric distortion and there are many others so benefits are limited at best. As such they are nothing at all like the professional systems.
3) The faster the system is run, the more subject to flakiness it gets.
You should look at SXAO (and other simple tip/tilt devices) as optical guiders. The advantage is that it is much easier and faster and more accurate to move a 2 oz. plate than a 30-100 pound mount.
In fact, I typically run mine at 7 second guide times.
It is also critical to be sure your calibration is accurate. Wind can mess that up as can poor balance. I run mine on an L-350 but with cheaper mounts one might see different mount responses to bumping in different parts of the sky so would need to be recalibrated for each object and maybe even after flips (my L-350 does not need to flip).
I would add that if one is drifting out of the “bump box” during exposures, it is probably your mount or polar alignment but could be wind or just bad seeing. I leave mine set at 80%. One thing I have noticed (and I suspect this is a bug) is that sometimes the first exposure will try to drift out of the box (and therefore bump the mount a lot) but all the other exposures do not. The exposure still comes out fine, however.
As far as PhD tracking with the SXAO, I typically see .3 RMS or more on poor nights, .2 to .3 on average nights, and .12 to .20 on good nights. But seeing at my remote site is well above average, sometimes dipping into sub-arcsec territory. Even with short (60 sec or so) unguided images I often see FWHM in the 1.5-2.5 range. With more normal main imager SXAO guided exposure lengths of 300-900 seconds that translates to getting sub-exposure image FWHM in the 2.0 to 2.5 arcsec range. My normal reject level for high res. images in the luminance is 2.3….
Overall the thing to realize is that the SXAO is not going to make things better by running it faster to make up for seeing. What it can do is to take some of the sting out of lesser performing mounts and improve the precision of guide moves on all mounts.
Hope this helps.
Thanks, Bill!
That is such useful information. It would have taken me ages to figure all of this out.
What you're saying lines up really well with what I've seen in my initial testing. I'll probably experiment with longer exposure times rathe than short now.
For instance, I redid my polar alignment after the frist night, and I was a bit off. The seeing was so much worse the two following nights, but I could still see that the polar alignment helped keeping the AO centered.
Thanks for sharing, Bill.
Dan
Respectful Supportive
Cyg avatar
I am also using an AO to do astrophotography on my Dobson vintage wooden/carbon 15"/1720mm focal length "only" with the help of an equatorial platform (TEPP).
It is to improve the guiding of such a configuration, with almost 100kg. It is not like a professional Adaptiv Optic at all.
It is not to try to fight the seeing, even the 1st order happens at a very high frequency, when pushing the Phd2 guiding frequency at some 0.2 or 0.1s the global FWHM is degrading. Having multi-star guiding on Phd2 is easy by using a big pixel camera and bin2, I selected the PlayerOne Xena-M with its 6um pixels with never any issue to get many guiding stars, execept at 0.1s when it sometimes lost the stars.
I will soon try with the help of an IR filter in front of the guiding camera to see if it is improving anythiing to the "false" movement due to the seeing, at this stage I keep a 1s frequency and sometimes 0.5s when it is a little windy.
You can check my gallery for examples although I still have many others to publish.
