Star Adventurer Target location aid
5 replies165 views
George avatar
I recently modified my simple astrophotography set up to aid in target location.
My basic system is a Canon 60D with Tamron 100-400mm lens and a Hoya Starscape filter, =12.0ptmounted on a Star Adventurer Pro 2i. This is not a go-to mount.
I built a bracket out of 3/8” Baltic Birch ply, which is quite stable.  The bracket is parallel to the lens axis and is mounted by an arc cut into the bracket which tightly fits the barrel of my lens, and by attachment to the camera hot shoe. Aluminum C channels hold my iPhone 11. The bracket also can hold a guide scope.
By using the “daytime” function on the PS Align program, I can quickly locate Polaris and then use the polar scope on the Star Adventurer to polar align.  I do final alignment using the ASIAIR Pro. With Polaris centered on my camera screen, I use the PS Align “sync-to-target button” to calibrate the phone to my set up.
 Using the DSO Database in PS Align, I locate a target, M101, which I will hop to from a star,  Mizar.  With Mizar in the crosshairs of PS Align, I would again center it on my camera screen and, if needed, sync again to ensure final calibration.  I hop to the target using the PS Align crosshairs and start the exposure sequence.
 The description is more complex than the use.  I can be polar aligned and on target in 20 minutes. This modification makes my system into a simple go-to mount.
Helpful Insightful Engaging
David Nozadze avatar
Hello George,
This is an excellent solution! Indeed, target location takes a lot of precious dark time, when not using a Go-To mount. I used to have green laser on a shoe mount, but it was impossible to alight properly with the camera's FOV. Yours is much more practical and smart!
Clear skies.
David
George avatar
David,
Thanks for your comments.  The thing that makes this work is the ability to calibrate the PS Align to account for alignment using the "snap to target.  Doing this on Polaris, and then again on a star near the target, results in reasonable accuracy for the final target.
Regards
George
Jonny Bravo avatar
You have an ASIAir… why not just use plate solving - especially since you're already using it to polar align? It seems like you're working way too hard.
Using your example of M101, you know the RA and Dec of the target (or you can easily look it up). Tapping the plate solve function on the ASIAir app will tell you the coordinates your are at currently. Rotate your gear in RA and Dec, hit plate solve again. Continue this until you have your target centered. If you know the sky and can star hop, you're already in the vicinity of the target, so making the final adjustments using plate solve and annotate in the ASIAir should take you very little time.
Well Written Helpful Insightful Concise Engaging
George avatar
Thanks.  I am fairly new to the ASIAIR and have used it in the manner you suggest.  I wanted folks to see a method to use with a tracker without the ASIAIR.
Jonny Bravo avatar
George:
Oh, that makes sense. Thanks for clarifying!
