Backyard, 70mm Meade Quadruplet on LX85.
ASI 071 MCP
I run sequences overnight using NINA to a laptop next to my scope. In the morning, before leaving for work, I cover the scope with a telegizmo if there is no serious rain predicted, otherwise I bring it inside.
Despite a dew heater the front lens may get a little moisture on it - the dew shield too. Should I wait to put the lens cap on?
The mount itself often has water on it as well - Should I refrain from covering it with the telegizmo till later in the day after it can dry out a bit?
THis morning it was clear out and I was able to run home and cover the scope and place lens cap on at about 11:00 AM, but this isn't always a possibility depending on my schedule.
I have seen different opinions on this elsewhere.
ZS
ASI 071 MCP
ZS
