WBPP issue
3 replies102 views
ScottF avatar
Hi, I’ve noticed when processing a large number of subs in WBPP/Pixinsight, it will often routinely select Fast Integration despite the fact that I have selected “Maximum quality with no compromises” in the preset menu. I don’t care how long it takes, I want maximum quality and I’m not sure why with that setting it would still select Fast integration. Is there a way to prevent this from happening or what do I need to alter in the settings to de-select it?
Sorry if it’s a dumb question, but I’d rather stay in PI for processing, and i’ve been jumping to APP when this happens.
Mikołaj Wadowski avatar
If you want to deselect Fast Integration, you uncheck the "Enable" box under the "Fast Integration" section. It could not be any simpler than this.
Well Written Concise
David Zimák avatar
Uncheck this box below as on the picture - Automatic integration mode
ScottF avatar
Thank you!
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
WBPP experiencing "Unknown exception" errors during "Measurements" — directly addresses Pixinsight WBPP processing issues.
Sep 28, 2025
