Biggest Newt You've Run on a Mach 2?
7 replies239 views
I'm toying with the idea of getting an imaging newt in 2026 or later and wondering how big some of you have gone for a Mach 2.  I've been chatting with Catalin from CFF and he makes a 250mm and a 300mm f3 Newt.
The 250 I think would be no problem, it is 15kg and 870mm long.  The 300 would be a killer f3 scope, but it's 19kg and 1020mm long, with a larger diameter pushing the weight even further out.  According to "Karen" the 250 should be no problem, it's handily in the Green, however the 300 is right on the edge of yellow.  Mounting the focuser and image train on the underside would definitely help.
I could always sell the Mach 2 and get an 1100/1150. But for the sake of this conversation would the Mach 2 be up to the task?
Hoping for some feedback from some folks who have mounted a big newt on a Mach 2 and can give some guidance.  Thanks!
Rick Krejci avatar
I had a 250 f4 newt on the Mach 2 and it did handle it fine…when the wind was calm.    Since I don't have a protective observatory, the 250 was an absolute wind sail and images from breezy nights were impacted.  The weight of a Newt is at each end and highest wind profile is at the camera end.   f3 would be shorter, but I'd imagine the mirror would be a bit heavier so the balance point wouldn't be mid-way on the tube.  Could be wrong about that.
If it's in an observatory, it should be much less of an issue.  Or a truss would be less prone to it
I went to a side-by-side 140 f7 APO and a 91 f4.9 Petzval and the Mach 2 handled it without issue and was less prone to wind.  Still in the green on the chart.
I'd be concerned with the combination of height + length + weight of a 12" even at f3 unless it's in a controlled area.
Arun H avatar
Rick Krejci:
I had a 250 f4 newt on the Mach 2 and it did handle it fine...when the wind was calm.    Since I don't have a protective observatory, the 250 was an absolute wind sail and images from breezy nights were impacted.  The weight of a Newt is at each end and highest wind profile is at the camera end.   f3 would be shorter, but I'd imagine the mirror would be a bit heavier so the balance point wouldn't be mid-way on the tube.  Could be wrong about that.
wind is a different beast than moment from weight. Wind load would depend cross sectional area and length from the point of rotation. The big issue with wind is that it will cause an unpredictable torque that can only be compensated for after the encoders detect the movement it causes and there will be a lag due to the inertia of the scope and counterweights before it can be compensated. By which time, the wind moment can change. Whereas the moment from the scope changes relatively slowly. Any scope that experiences a wind moment that is large in comparison to the moment caused by its weight would create a problem for any mount regardless of weight capacity. I don’t believe the Mach2 or any AP graph makes a claim that anything in the green would be wind resistant.
Helpful Insightful
I'm at HCRO inside a large Observatory. There are rarely any issues with wind, it just dies right down at sunset. I think in the lastvyear there was one night that the roof was closed all night from wind (10+mph).
Thanks Rick. I appreciate hearing about your experience with a 250.  Im probably leaning that way just because the 300 is so much bigger
Rick Krejci avatar
Arun H:
Rick Krejci:
I understand.   I'm just relaying my experience with a 10" newt on a Mach 2.
John Stone avatar
I’ve got a 58” long, 50 lb, TOA-130 on my Mach2 that tracks sub 0.3” RMS (and sometimes sub 0.2” RMS).
It’s not wind sail but it’s longer and just as heavy as that Newt would be. In fact it’s 5 lbs above the line in the Dec chart but still works great.
That newt would be way below the line in the Dec chart and just half-way through the ‘extended performance’ yellow area in RA.
I’d take a chance on it. I’d be very surprised if there were any problems in an observatory.
ScottF avatar
I have an 11” Rasa which weights 43 lbs, plus computer, celestron dew heater and camera, photon cage, etc. , so the actual weight is a few pounds more and it’s about 838mm long not including the camera/lens shield on my Mach2 and it seems to function well. It is housed in a ROR backyard observatory so wind is not usually an issue.
Astro Physics Mount Nirvana at last with AP 1100 and AP Mach 2 mounts (and Takahashi/Stellarvue Scopes) perfectly tuned!
I just wanted to write a short ode to AP mounts, AP customer service, and the ONE GUY who literally helped me set up and "tune" to perfection two complicated systems so they run like clockwork, Bill from Dark Matters Astro (www.darkmattersa...
Discussion of AP mounts (Mach 2) with experienced users sharing configurations.
Apr 10, 2025
Which newton scope for observatory
This year I will do an upgrade from a newton 200 F5. I'm hesitating between a 250 F4 or a 300 F4 with a 3" 1.14 coma corrector. The mount can handle the weight and its inside an observatory. Thx for the feedback
Addresses Newton telescope sizing on mounts; relevant to mount capacity concerns.
Jul 4, 2025
