Halo artefact or something else?
1 reply59 views
Tim Richter avatar
Hello astronomers!
I am currently working on a SHO Mosaic image in cygnus. Ha is already done, I am now moving to OIII.
This is one of the 4 OIII panels, and I am not really sure what this artefact on the bottom is. It could be from the star Sadr, which is in the panel below.
This artefact is only in this panel (in all of the sub frames), the other panels are fine. Thus, I rule out issues with flat frames.
Setup:
Telescope: Sharpstar 130HNT Newton
Camera: ZWO ASi 1600MM
Filter: Optolong OIII
Any ideas?
A light leak or unwanted internal reflections from Sadr or a local light source would be my best guess
. I did a detail of NGC 1318 and had a visible diffraction spike from Sadr even though it was well out of the FOV. Working near a very bright star like that can have issues. I couldn't do anything about the diffraction spike but in your case, if it is an internal reflection or light leak, it should be fixable.
Can your OTA pass the daytime dark frame test?
Helpful Insightful Respectful
Updated IODT rules
Hey, I think that the recent changes regarding the iodt rules are fine except for one thing. Submitting an image that you already submitted in the past is forbidden. This applies also in the event in which you completely re-processed the image, or yo...
Discusses mosaic panel creation, relevant to revision upload guidelines.
Nov 12, 2023
My littte bad weather project: Sharpstar 13028HNT modification
Due to bad weather in Germany, I wanted to do some modifications to my Sharpstar 13028HNT. I’d like to share my first experiences with these modifications, though there is still more to do. A few things I wanted to try:Create a new mirror mask (notch...
Author uses same telescope model; modification experiences may be relevant.
Dec 12, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan vibration artifacts could explain mysterious panel artifacts in imaging.
Nov 18, 2025
Dark bands at top and bottom of Minicam8M
EDIT: QHY support responded with the following statement: “We can basically confirm that this phenomenon stems from the light-gathering limitations of the Minicam8M sensor structure at extremely fast focal ratios (F4), rather than from mechanical obs...
Dark bands artifact similar to author's unexplained bottom panel artifact issue.
Nov 8, 2025
