Monitoring a remote observatory - web connected cameras
jonathan.shinn avatar
Now I’m imaging from within the house I don’t get to monitor my mount and scope. Last night Astroberry didn’t ‘meridian flip’ when I expected it to and crashed the camera into the pier. Do any of you have cameras in your observatories and if so what would you recommend please?
maxchess avatar
Jonathan, sorry to hear about your Meridian crash. It happens. I have always been nervous about an unattended flip. Have you set mount limits in EKOS(Astroberry) ? These stop the mount tracking if it goes too far past the Meridian.  My setup is also in a roll off shed and I installed a cheap IP camera I got on ebay for around £20 so I could watch remotely(Switch off the IR for imaging).  I also did a simulated daytime flip to check everything worked.
I run a free piece of software called Ispy.
This assumes that you have a network connection to your OBS-shed. Mine is too far away to for wifi to reach, but I do have power via a very long extension cable, so I connected a   powerline unit  at each end and now have an ethernet connection to the scope.
There is a thread on Indi/EKOS(aka Astroberry)  support aboutflip crashes.  If you cannot fix it, I suggest you post there. They are very responsive.
I hope your gear survived the collision
Max
Planning my Observatory Building
Greetings to the community, I've been thinking for some time now about building my own observatory. At the moment, I have three setups in my backyard. These are out 24/7. The first one is out there for about two years now. Everything is covered w...
Observatory building relevant to monitoring equipment from indoors.
Sep 6, 2023
How I build my observatory and what I would do different if I had to do it all over.
Before I start. English is not my first language, so I'm sorry if there are misspellings or maybe the way I phrase things are not correct. I did my best. Why an observatory? When I started this hobby back in 2018, I bought a used C8 Edge HD on a ...
Observatory design experience may address monitoring and safety concerns.
Sep 28, 2023
Problems with Solve/Meridianflip - NINA & EQ-6R Pro
Hello everyone from Germany! I had to fight yesterday with a massive problem and have read me until today through endless forum posts and possible solutions without getting a step further, so I hope that someone can help me or give me an advise. In t...
Directly addresses meridian flip problems with automation software.
Sep 10, 2023
Meridian flip with NINA
I began using NINA when my GEM45 arrived and it's meridian flips were flawless. However, the last two times out I've used my GEM28 and after the flip, my mount becomes unresponsive to slew commands, even the hand controller will not work. I h...
Discusses meridian flip issues with different mount models.
Jul 25, 2023
