Subframe Duration under These Conditions
2 replies210 views
Jerry Gerber avatar
Hi!
I'm imaging VdB 158 tonight.   The moon is 74% full and is at a distance of a little over 112 degrees from the object.
I plan on imaging in RGB, foregoing L due to moonlight.  This is under a Bortle 1 sky and should be very clear all night.
Is a 180" subframe exposure optimal, or should I go to 90"?
If I go to 90 seconds, then I have to use another set of 90" darks.  How will WBPP know which darks go with which lights?  I usually have all my darks in one folder but in this case the other 3 nights I've been imaging this object I've been using 180 second subs.
Jerry
I wouldn't fuss around, just get what is easiest to you. At that distance I would be tempted to go 300s and damn the torpedoes.
John Stone avatar
If you want, you can install the NINA "Optimal Exposure Calculator" plugin and it will use your SharpCap sensor evaluation and a snapshot of your target to tell you the optimal exposure time (a.k.a. swamp the read noise by 10x) for that target, on that day, at that time.
L-Ultimate Under Full Moon
Hi everyone. I was wondering what's your take on using the L-Ultimate under a full moon? ​​My target will be about 45+ degrees away from the rising position. Will I still get good Ha and OIII data? Or, am I wasting my time and should wait for ano...
Relevant - discusses moon phase effects on narrowband imaging data quality.
Sep 15, 2024
C/2023 A3 tracking speed
I'm planning on imaging the comet tonight, I'm using a star adventurer 2i, and am wondering what my tracking speed should be.
Relevant - discusses imaging setup considerations, though different tracker model than author's.
Oct 19, 2024
What is the best/right gain and temperature for the Zwo 183mc pro?
Hi guys. As some of you know I image mostly with the Rasa 8 equipped with the Zwo 183mc pro camera. I have been imaging at different gains at times and same temperature. But I will like to stick to one gain for a specific filter and sky conditions. W...
Discusses gain and temperature settings for imaging under different sky conditions.
Sep 27, 2023
Blending RGB OSC with L-Enhance data - ZWO 294MC Pro
Hey Everyone! After trying to find a forum topic to answer my question, I was not able to properly get the answer I am looking for. First of all, I image with a refractor telescope using a 294MC Pro. I usually only use no filters at all in Bortle5 or...
Moon glow filtering relevant to author's stated imaging conditions and filters.
Sep 6, 2023
Very Weird NINA Behavior (or ASCOM?)
Are there any known new bugs in the latest versions of ASCOM and/or NINA? Last night all the images were taken properly but NINA's sequencer shows that only 1 out of 45 blue filter images were taken when in fact I just downloaded 180 images plus ...
Discusses NINA software which author uses for astrophotography imaging sequences.
Dec 18, 2025
