A Comparison - Fast vs. Large
19 replies•1.4k views
Of the many diatribes in AP world one of the most recurrent is the role that "fast" optics plays in achieving a given result or more generally speaking whether being "fast" is better than being "large". And here is the comparison:
In one corner stands the champ, an 20" AG iDK running at around f/6.8 and sporting the best in prosumer CCD tech, a FLI PL16803. It is located in the mountains of the Namib (at ~1600m a.s.l.), with average seeing below 1.5" and with a sky the would melt the most hardened APer's heart, at B1 (I would spend hours just watching the whole-sky camera some nights!).
In the opposite corner is the challenger, a 2nd hand Nikon Nikkor 300mm AFS-ED (got it relatively cheap because some minor fungus) sporting a blazing fast f/2.8 optics and shooting from my dreadful backyard, with conspicuous light pollution (courtesy of the nearby industrial estate) to my S and W, with a zenith Bortle scale of B7 (18.35 m per square asec) on a good day and rather worse than that when the sky is affected by haze and thin cirrus clouds which is more often than not. It is also sitting at the vertiginous height of 23m a.s.l. The lens is fitted with a IMX571 OSC sensor and at least this last piece of hardware is fairly modern.
The object: Abell 31 (PK219+31.1), a large faint PN located in Cancer at Declination 8deg 48' N
The kitting: The iDK is running OIII and Ha Astrodon 6nm filters, equally split+ integrations of 600s in bin 2x2 while the Nikon is running an ALP-T 5nm DB (Ha and OIII) filter with 2/3 of the exposures of 180s and the remainder using 300s integrations.
The results:
The total integrated light for the iDK has been scaled to match the image scale of the Nikon and both framed in the same way (within few pixels). In both cases no processing was done other than standard CC and auto-stretching. The IMX571 image has been CFA drizzled for this presentation's purposes so it is somewhat of lower SNR than the un-drizzled counterpart (which is the one actually used for the final image).
And here is the relevant parameters' table to make the comparison both meaningful and worthwhile:
The last column gives the equivalent exposure of the Nikon normalized to that of the iDK and as can be seen is significantly lower than that. Unaccounted for in the calculations carried out in the table above is the relative effect of the altitude of the two locations, which isn't trivial but hard to work out in actual hard numbers. Also, the different climates isn't accounted for (as in air transparency /moisture) which is expected to be better (like a lot) in the dry scrublands of the Namib w.r.t to the "anything goes as long isn't really cloudy", which is the standard operating mode for my backyard observations.
The effect of the different Bortle classes (which might be contentious to some) has been carried assuming each increase in Bortle class carries a penalty of 12.5% more imaging time for same results when using NB filters (of reasonably close pass-bands). With 6 classes of difference (and that at the zenith folks!) this results in a factor of (1+ 0.125)^6 = 2.03. Also, the efficiency loss of using an OSC camera opposed to a monochromatic one has been assumed to be 0.9 across the board. Also, no accounting for the difference in QE between the two cameras was considered but the 16803 sensor is a top notch CCD sensor with very high overall QE, comparable to that of the IMX571 sensor.  Also, the ALP-T filter isn't the High-Speed version but the standard version, with a drop of efficiency of around 20% in OIII band and somewhat less for the Ha band. This hasn't been accounted for in the calculations. In both cases the effect of the Moon and her phase is assumed to be trivial.
Passing to comparing the actual results four things seem to be clear, at least to me:
1. The iDK image has a much more pleasing background noise, very uniform without clustering while the Nikon's show some clustering which I think is a direct result of the poorer sky conditions globally.
2. The OIII signal is somewhat stronger in the iDK image w.r.t. the Nikon's (could be more than few things playing here, discounting exposure times, notably absorptions at the shorter wavelength)
3. The Ha signal is signally stronger for the Nikon that is for the iDK  and while not shown clearly in the image, there is a very low brightness Ha area to the south of the PN which is picked by the Nikon but not in the iDK's.
4. Resolution is way better for the iDK, but that doesn't bring much joy in the Ha outer shell since the signal there is weak.
My conclusion: F ratio matters
P.S.: Probably more important: Do not waste money on remote telescope time in NB unless resolution is paramount.
Charles Hagen avatar
The number one rule of good testing is that you change precisely one variable at a time and you keep all others the same. I think you have managed to change literally every variable. Different optical design, different sensor, different pixel size, different pixel technology, OSC and mono being compared, different filters, different conditions, different hemispheres… and yet you still draw a conclusion.
Shinpah avatar
The easiest way to do this comparison properly in the future is to simply compare a fast mild telephoto, perhaps an 85 or 135mm lens at f/2.8, with something like a 500mm or 600mm f/5.6 or f6.3 lens. using the same equipment in the same location.
Kristof Vandebeek avatar
Georg N. Nyman avatar
Comparing with a Nikon AF-S at f/2.8 is not an optimal comparison. If you like to compare a 20" as the giant with a fast one, take a RASA and compare it. In the Nikon lens, you find probably about 12 lenses with many surfaces which are detrimental to the overall contrast and transmission outside the "normal" range of wavelengths.
A RASA would be the much better choice for a side-by-side comparision, I think.
Deepan Vishal avatar
I agree with Charles Hagen’s comments. I wouldn’t use this test to make a conclusion. But great practical example showing good results with extremely different setups.
Tobiasz avatar
Kristof Vandebeek:
There’s a similar thread about this on https://www.cloudynights.com/topic/660553-etendue-calculator/ , it is worth a read.
A nice calculator can be found here:
https://lambermont.dyndns.org/astro/code/compare-telescopes.html?a&d1=100&l1=500&c1p=2.315&d2=100&l2=1000&c2p=4.63
+1 for the second link. It is always very useful to compare how much per pixel signal you receive at which sampling rate.
John Hayes avatar
Making a measurement to assess differences like this is tricky and it requires a careful methodology to isolate what you want to measure and to control uncertainties.  I see these kinds of comparisons come up all the time and very few of them appear to be done correctly.   I'm not going to pass any judgement on what the OP did here but I think that it's far more valuable to understand the underlying optical theory that governs what you get from an imaging system with respect to its first order parameters.  This presentation is an attempt to look at why big telescopes are better and it goes into how aperture and focal ratio play into image quality and signal strength.
https://www.youtube.com/watch?v=HiJoqQp1qFI
And, if you are careful, everything shown in this presentation is measurable.
Olivier Constans avatar
I will only share my experience because I have the chance to own fast and slow instruments:
I have 2 different setup , one is a RC10 I use with  1523mm  F/6 of focal length (reducer)  and the other one is the sharpcap 13028HNT that is F/2.8 and 360mm focal length.  I have used both with the same IMX571 color so I can compare. I also have a RC8 I used at F 5.3 with reducer.
if the fast scope is …fast, I prefer the slow one because at the end the picture contains much more details and also  has more small of faint objects. Also wide field pictures from fast instrument  are fantastic to see until you zoom inside and see pixels instead of stars.. with the slow instrument and big diameter you can get very small  galaxy details when zooming before going to pixels. Also fast and wide field instrument are very frustrating because subject to have a lot of brigth satelittes trails when a slower one will have less chance to have dozen of satelittes trails and those are often less brigth and easier to remove.
I compared last week a RC10 F/6 and a RC8 F/5.3  I have because I am doing pictures of the same object in paralell with both instruments , after the same amount of time the RC10 reach magnitude 21.4 when RC8 reeach 20.5. I assume a 5 or 6 inch aperture with short focal  will go barely to magnitude 18 in the same amount of time. I think there is no miracle at the end the bigger the diameter is the more information you will get in your final picture.
This is the main reason I choose to buy a RC10 instead of a fast refractor that is more or less the price.  I prefer deep view in a smaller field than a large field wih very few details in it even if it takes more time  (not so much)  to get faint objects.
If you want to have good details with a fast instrument, you will need to go to camera with very tiny pixels and in that case with today sensors at a reasonnable price , you will get less field of view and reduce the sampling, in the end you will be near to the slow instrument with bigger pixels I think but you you will not reach the same limiting magnitude because diameter is smaller in fast instrument (unless you use a rasa 11 of course …)
So this was just my opinion based on my experience and basic knwoledge
Brian Diaz avatar
hi, everyone
this is just a basic guide
fast and large = super excellent (five stars)
fast = excellent(4 stars)
large = good(3 stars)
small OTA and slow= not very good(2stars)
this comparison is based on the same conditions, same filters, camera, and everything else.
and the quality of the OTA ( 50%) is super important.
ScottF avatar
It’s nice to see the comparison, but as mentioned, there are far too many variables for an accurate assessment. I’ve seen tests like this where a large aperture slow scope is compared to say a short focal length RASA shooting the same target, but usually it’s a very small object that the RASA is not suited for and I don’t understand the comparison.
John Hayes avatar
Brian Diaz · Aug 13, 2025 at 02:30 PM
hi, everyone
Brian,
Where in the world did you get this notion? When we talk about aperture and speed, different optical systems are suited to different tasks and the results you can get depends on how the imaging system is configured. And all of that is driven by optical principles; not folklore. Have you reviewed the presentation that I referenced above?
Brian Diaz avatar
John Hayes · Aug 14, 2025, 03:35 PM
hi, everyone
Brian,
hi,john
I don't know what you're referring , but anyone with a small, slow OTA isn't very good. For some reason, if you looked at the market, we have triple, quadruple, quintuple. My information is based on years of having poor, average, and good quality OTAs, and I don't think a slow, double, and poor-quality OTA has any specific use other than being a good salesperson.
However, can you tell me a good use for a small, slow OTA? In astrophotography, maybe there is, but when you compare it with a small, fast, and good-quality OTA, then my rule does apply.
John Hayes avatar
Brian Diaz · Aug 14, 2025, 07:11 PM
hi, everyone
Brian,
hi,john
I’m referring to this presentation: https://www.youtube.com/watch?v=HiJoqQp1qFI.
A F/10, Edge 8 is perfectly suitable for imaging galaxies (and I don’t think that anyone who has one “isn’t very good.”) If you select the right sensors, an 8”, F/10 system can produce the same signal as an 8”, F/3 system. In that case, the faster system is useful for producing a wider field; not more signal. I guess I don’t know what you mean by “triple, quadruple, quintuple” in the market. I’m talking about the physics that govern imaging as a function of aperture size and optical speed. If you are simply saying that poor quality optics are no good, then I agree. If you watch my presentation, you’ll see that aperture is the main figure of merit for most telescopes and that’s why professional telescopes keep getting bigger and bigger. Optical speed generally relates to the field of view; although it can also help to further increase the signal for stars. LLST is an interesting limiting case where the science objective requires a huge field of view to find super faint point sources, which is why that telescope is a F/1.2, 8.4-m system.
Helpful Insightful
MaksPower avatar
Sure the little rigs can be impressive for what they are but the noise, and the exposure needed to overcome it… sheesh.
Simple - Aperture counts. What you do with it - compress the focal length for a wider field, or go long for sheer scale - is up to you. The little APOs can impress but they take all night to match what my 10" can grab in an hour. But they can't do the scale for small, deep targets.
Nonetheless I remain impressed by what's possible from the little Seestars.
SemiPro avatar
Kristof Vandebeek:
That is a very good calculator that I used all the time.
John Hayes:
Said calculator actually ties in very nice with this video.
Arun H avatar
I guess the way I look at it is simple.
Start with the field you want to image.
For a given field, the system (includes sensor, reducer etc.) with the largest aperture will always give you the better result. Focal length and sensor dimensions determine your FOV. Given this FOV, a larger aperture system will do better, always, when normalized to a common pixel size.
Arun H:
...for the same amount of time.
MaksPower avatar
I had images of the Pillars of Creation from two scopes f/5 vs f/12, same camera, same filter, same exposure, and I’ve shown crops of the same region at the same scale here https://app.astrobin.com/forum/topic/185464?page=3#post-204047
Same field, same scale…
Aperture and focal length win over focal ratio. It just takes longer to get the result.
Not my contention.
