Santiago García Mahía avatar
Hi everyone. I'm new to this, and yesterday was the first time I tried attaching the camera to the telescope.
I have the Skywatcher Newton 150/750 PDS and the ZWO ASI662 camera.
When I tried it with the camera and its original head, I was able to record myself using Firecaptura, or even with N.I.N.A. I could also photograph myself.
The problem arose when I removed the camera head to leave it with the sensor uncovered, so all I see is white noise that changes color depending on whether it's dark or not, but nothing else is visible.
When I attached the camera to the telescope using the 1.25 barrel that comes with the camera in its box, I also couldn't see anything. The same white noise, but darker since it was nighttime and I was pointing at the sky.
With N.I.N.A., I immediately get an error with plate solving because it can't find any stars.
I haven't tried anything else; there were no planets or moons to photograph that night, so I didn't try the Barlow lens either.
Does anyone know why this might be?
Thanky so much
Helpful Respectful Engaging
Robyn Smith avatar
I’m also very new to this but after two nights trying to photograph (video) Saturn with a Skymax 102 and ZWO ASI662MC I learned a few things that might be relevant to you.
  1. At first I couldn’t not see anything with the camera using the 1.25 nosepiece directly where my eye-piece would normally go. I had Saturn in a 32mm Plossl but figured out that the camera sensor is so small that it was not even in frame. I solved this by using a 12mm eyepiece with crosshairs and placing Saturn (You could do the same with a bright star) dead center.
  2. I also figured out with my f13 scope, the camera gain and exposure time had to be turned up significantly. Try something like 300 gain and 60ms exposure, your OTA is faster than mine so you might not need as much. Maybe even 200 gain will be enough but it shouldn’t hurt to crank it up to center and focus.
  3. I figured out that the focus for my visual eyepieces is much different than for the camera focal plane. Once I solved the first two issues, I had light on the camera sensor but it was a big blob. I got the focus close and then a bahtinov mask to get “perfect” focus. You’ll probably need to increase expose to see anything when you add the mask.
Anyway, Hope some of this helps. I also hope you have a solid mount because you’ll want it tracking very well to keep your target in the frame. I like to watch it in the 12mm crosshairs for a bit to make sure it’s not drifting. If your target is drifting quickly across the frame it will be impossible to remove the eyepiece and get the camera mounted before you are just seeing black again.
Thank you so much for your detailed response. Finally, the problem was the low Gain and due the focuser has a short way between focused and non-focused.
I did this Moon mosaic when I fixed the inssues (Is and screenshot of the original pictures because the máximum siz must be 1Mb)
ASI AIR PRO + Nikon Z6ii Image Problem
Hello! Tonight I tried imaging with my ASI AIR Pro and my Nikon Z6ii, but had some problems with how the images appeared on the display. It appeared that every photo I took was delayed by 2 photos. Ex: I took a preview pic of Jupiter for a sanity che...
ZWO camera setup issues; may share similar hardware compatibility problems.
Mar 11, 2024
solar imaging with daystar quark and z61
Good evening everyone I need some help, I recently purchased a daystar quark and I am trying to image using a WO ZS61 telescope. I have tries everything and no matter what I cant seem to be able to see anything. I was wondering if anyone using this s...
ZWO camera troubleshooting with telescope setup similar to author's configuration.
Oct 28, 2024
Similar camera and telescope setup troubleshooting for astrophotography imaging.
Oct 28, 2024
Why am I getting these star bursts?
Hey all, first time poster, long time lurker and I need some help. I've been working on some data I gathered on the Horsehead and Flame and I can't seem to figure out why I have these starbursts(lines, streaks? I'm not exactly sure what t...
Equipment troubleshooting with similar telescope and camera setup.
Oct 25, 2023
Imaging with Coronado PST - Can't find focus
I know it's possible to image with this scope but I just can't get anywhere near focus. here's what I've tried: ASI662MC - 1.25" nosepiece inserted straight into the eyepiece holder. I can't seem to get the sensor close enoug...
Problem ZWO ASI 662 and SW 150/750 — addresses camera focus issues with similar camera model.
Jul 8, 2024
