Jordan Morley avatar
hey everyone
my current scope is a 60mm sharpstar edphii refractor, its nice however id like to get into reflectors! im using a heq5 pro and am thinking a 130pds would suit it well. if anybody could recommend me accessories and a coma corrector that would be great. the ts optics correctors seem great, was thinking the tsgpu would be the way to go however i have no clue or experience with reflectors.
oh is anybody running a focus cube v2 on there 130pds? does the standard bracket fit?
thanks in advance~
jordan
CCDMike avatar
Hi Jordan,
from my POV you don't need the GPU on the 130PDS (but I would recommend it for faster scopes). The MPCC works well on f5. I have both and have tested it. You may look on some images made with this combination in my gallery.
I would strongly recommend to put some velour in the tube and install an aperture ring.
On my 130 is an Arduino, so I can't tell anything to the focus cube.
Have fun with it! It's a nice little fellow!
Mike
Helpful Concise Supportive
Andy Wray avatar
I use the Skywatcher 2" coma corrector on my 200PDS and it works very well (nice round stars across the entire image).  It was a huge improvement over the stock 200PDS.
Well Written Concise
Tristan Campbell avatar
I recently acquired a 150pds and made this list of mods - virtually all would apply to the 130pds too. Key one for me is an aperture mask for mirror to improve stars.
https://www.absolutelynothing.co.uk/blog/skywatcher-150pds-modifications/
skywatcher coma corrector is excellent- have had great results on 150pds, 200pds and 250pds with it.
Abhijit Juvekar avatar
I have similar setup like yours.
I have been using SW 130PDS for more than 2 years now & it is very good short tube Newtonian for medium size targets like open clusters, nebulae etc.
Not much suitable for deep field galaxies or planetary nebulae for that I use GSO 6 inch F9 RC.
I also have Sharpstar 60ED APO refractor which I like the most for it's image quality.
I have ZWO ASI 1600MM-PRO camera with LRGB and Narrowband filters for above telescopes setup.
My recommendation is to get 130PDS for it's great value for money and compact size.
thanks everyone for the replys very helpful stuff! looks like i do need some accessories to budget for lol
jordan
Werny Michael avatar
For SW Newton, i Use a Baader ClickLock ;)
Dave B avatar
If you use a baader click lock beware it will push the drawtube further into the ota and eat into your stars , if you can connect using a m48/54 adapter less chance of tilt  https://www.firstlightoptics.com/adapters/astro-essentials-m48-adapter-for-sky-watcher-newtonians-and-72ed-refractor-m54.html
 also think about changing the dovetail to a longer one as it becomes camera heavy using a longer dovetail let’s you compensate for that trying to find a balance point
Dave B:
 also think about changing the dovetail to a longer one as it becomes camera heavy using a longer dovetail let’s you compensate for that trying to find a balance.
baader quicklock and this adapter can be used with camera, filterdraw, extention tubes etc or is it just for eye pieces? at the moment i went with a cheap 2" compression ring. as for dovetail i have a large geoptik that should work a treat!
jordan
Dave B avatar
Jordan Morley:
Dave B:
jordan
Yes you can use camera  ,filter wheel etc , a cliclock holds very very well especially when you’ve an expensive camera hanging upside down , a threaded is used to try to eliminate any tilt to the system.
