Continuum subtraction in nebulas
3 replies248 views
THIAGO GILBERTO DO PRADO avatar
There are several ways to do continuum subtraction in Pixinsight. But which one best suits the M8?
Tommi Liinalampi avatar
I'm not sure about these several ways, but I have my own method. I perform SPFC using NB method and Ha wavelength/bandwidth for grey channel. I do this for both red and Ha channel. When I have scaling factors I just scale Ha channel to match red channel flux (in Ha wavelengths). Then I just subtract red channel from Ha channel. This could be the most accurate way to do continuun subtraction and you get right factors from Gaia database.
Sean Makin avatar
I use @Charles Hagen's photometric continuum subtraction script, and add the narrowband back with the pixelmath he outlines here.
Sean Makin:
Tommi Liinalampi:
I've used this script before; it worked on some nebulae, but it wasn't satisfactory for M8. The method mentioned in Tommi's comment seems interesting. I'll give it a try. I don't know if you're feeling the same way, but it seems that the more data there is, the more difficult it is for the subtraction to be efficient.
"Emissionless" Processing - Advanced Technique for Isolating Emission and Continuum Components
Hello everyone! Not too long ago I compiled a step-by-step guide for subtracting emission from broadband images. Some of you might be familiar with continuum subtraction - this is similar in principle, just instead of subtracting the continuum, you s...
Directly addresses continuum subtraction techniques for emission nebulae like M8.
Aug 22, 2025
