Something Wrong With My, Seastar? How can I fix it?
4 replies314 views
Szijártó Áron avatar
Hello and welcome.
I'd like to ask everyone who is using the Seastar or they have experience in this situation. As of right now, im trying to polar align my Seastar, which I did.
And I come across this issue here. Instead of looking up in the sky, my seastar is looking downwards or not looking at the sky at all just a random direction.
Has anyone met this issue or knows how to address this?
Cause im seriously don't know what I'm doing wrong here.  Or what's happening?
Astroguy3236 avatar
I had the same problem as you did until I looked at the diagram when setting up for EQ mode. Make sure your power button/battery strength is pointing upwards. It won't plate solve unless you pay attention to the direction of the battery scale/ power button pointing up. Just look at the EQ mode diagram and it should work the way it should.
Vroomfondel avatar
Yep. Seems like you just need to reposition your S50. See attached screenshot (courtesy of Agena Astro shop).
Joe Segal avatar
What steps did you take before this ? What direction was button facing when you started?   if eq mode should face down to start.
Joe Segal:
What steps did you take before this? What direction was the button facing when you started? If the EQ mode should face down to start.
I usually set it up looking in the opposite direction of my house, which is south, and the garden is north.
And since the house is in the south I set it to face the north.
And as the app says it should be facing the sky.
Like in the image I showed.
Guess I didn't really set it up to face the sky completely?
What causes this?
It's the same direction across the image, only on the brightest stars. BlurX doesn't get rid of it except for the faintest ones (correct only). I tried channel match, and to correct the big stars, the small ones are way out of whack. Does any...
Discusses equipment issues; may help identify if problem is hardware-related.
Mar 20, 2024
Need Help Processing Comet Images Taken With seastar
Hello everyone! I’m reaching out because I’m feeling a bit lost when it comes to processing comet images taken with the Seastar. This year, I captured two different comets, but I'm not sure how to process them. I tried following the tutorial from Dee...
Processing comet images taken with Seastar camera; directly relevant.
Sep 3, 2025
