Deniz Üzel avatar
Hello,
I am intrested in DSO astrophotography for a while now and whant to build my own rig. I am still between 3 scopes wich are the Red-Cat 51, Red-Cat 71 and the Zenithstar 73. As camera i was thinking to get ASI585MC Pro to begin with. What will your suggestion be for me.
Thank you, Deniz
Clear Skies
Dunk avatar
As I'm sure everyone is going to say: you didn't mention which mount? This is almost more-important than the scope or camera and should probably be your first cost to figure out…
(All 3 scopes you mention are fantastic first scopes btw and are all quite lightweight and easy for almost any mount on the market. And the 585MC Pro is also great. You could also look at the 533MC Pro if you can afford).
And then you'll likely want a electronic focuser, filter(s), a filter drawer… the list is long.. :-)
Dunk avatar
If you are in the US there is both a Redcat-51 and 71 for sale on marketplace right now - they both come with a bunch of other goodies also..
Tommi Liinalampi avatar
I would buy some Askar scope. Much more cost-effective solution than WO scope. If you would like to buy a fast wide field scope then Askar FRA400 with F/3.9 reducer will be a good option. Faster and cheaper than Redcat 71 but you still get very sharp images.
I have also owned WO Zenithstar 81 and I would say that Askar FRA400 beat Zenithstar-option 10-0.
Deniz Üzel avatar
Hello, thank you for the responces. Sorry for not mentioning my mount, i was thinking of heq 5 pro or ZWO AM3. I am very confused about how these scopes changes the image for me and wich one would be the best option for me as well. Also my budget is a little elastic, i can switch on buying a Red-Cat 91 as well. But as i said i am very confused about what would change for me. Also in my rig i will get the ZWO EAF, Guide cams and asi air plus all the stuff. If you have any suggestions on my first rig setup i will definetly think on it. I am very open to suggestion. Thank you.
Clear Skies
Aloke Palsikar avatar
If you are looking at Red Cat 51, would recommend if you can also look at Askar SQA 55.  Almost similar specs but much lower in price.  As regards Mount if you are considering ZWO AM3 then you may look at AM5N  instead as it is more robust and can carry a larger payload which you may require as your grow your kit going ahead
You will require other accessories like a controller. say ZWO ASI Air Plus ( incase you want to go for a all ZWO option) .  In addition you may want to consider guiding equipment . A 30/60 mm Guide scope or an alternative in form of Off Axis Guider (OAG) may  be considered.
As you progress other accessories like Filters, Filter Wheel, EAF etc may be obtained as you expand your budget !
Deniz Üzel avatar
Thanl you Aloke. One question. How do i polar align with a ZWO mount ? Is it posible without using a software such as ASIAIR. Also do you think i should go for a asi533mc pro or asi585mc pro ?
Dunk avatar
My strongest recommendation is to buy used gear until you are deeper into this hobby and have figured out what you want.
Everything above from everyone is good advice.
Deniz Üzel avatar
Thank you so much for the quick recponces i will definetly consider every thing you guys suggested to me.
Deniz Üzel:
If you have a ZWO ASI Air then Polar Alignment is an integral feature of the controller.  After a few attempts till you get used to, it is  easy and can be done in less than 5-10 min with a reasonable accuracy.   If you are not using ASI Air then you can try using some Open Source Softwares like PHD2 or N.I.N.A  which will give you a similar result
On camera, I personally have a ZWO ASI 533 MC Pro and am quite satisfied with the performance.  You can decide based on your Budget and choice.  585 MC is also good entry level camera and you can try it  as well.  The difference is in the specifications of the SONY sensors in both.  You can compare the Sony sensors IMX 533 with IMS 585 and take a call.
All the best
Stjepan Prugovečki avatar
There are 3 important things in astrophotography : Mount, mount and …. mount . Joke aside, but good mount is your base that you build upon.  Perhaps , iOptron HAE 29, ZWO AM5 , or if you are not in USA  you can get Ragdoll mount (good, reasonably priced from proxisky.com).  As the scope is concerned , Redcats are good choice, but price/performance is not the best . As mentioned before, Askar scopes do have better price/performance ratio. In fact, I think that currently the best price/performance for small refractor is SW Esprit 80 , if you can still find one. No, it is not Petzval, but it is razor-sharp, and a good offers can still be found. AsiAir gives you quick start , but up to large extent binds you to ZWO. I would rather buy miniPC and install  NINA and PHD2. It takes a bit of an effort to learn a bit , but gives you a total freedom.  So, if you save a bit on the mount and scope, you can invest that money into Touptek 571 camera (does not work with ASiAir though)
TiffsAndAstro avatar
Deniz Üzel:
Clear Skies
You can put scope and camera details into telescopius.com and see how various targets frame up.
Michael Nemetz avatar
Or look for an Apertura CarbonStar 150 Newton, forget about all that fearmongering about collimating and enjoy a real keeper telescope.
dkamen avatar
I
Deniz Üzel:
Hello,
Thank you, Deniz
Clear Skies
I have the ZS73ii and the RedCat71.
The latter is clearly superior in every regard, but the 73 is also quite decent and a tad more lightweight.
Keep in mind the 73 has no flattener built-in, you will have to buy one and get the spacing right so factor that in when comparing prices.
Redcat 51 is significantly smaller and lighter, extremely portable actually, I think it makes more sense for a beginner.
Rajat Kumar avatar
@Deniz Üzel i am currently using Z73. Have used GEM28, AM3 (borrowed for a short while) and currently using Ioptron HAE29C. The only difference is that I have a 2600 MC and not 585 sensor.
Regarding the Z73, you would need a flattener. If I had an option between Z73 and Redcat 71, I would go with Redcat. The Z73... From where do I start. I hated it when I got it. The stars were really bad because of which the images looked very very bad. After wasting a couple of months and going through everything that internet had to offer, the issues remained unresolved. Ultimately, after consulting a senior member of our astronomy society, we decided to use a 2mm aperture mask and see what happened. I think the front lens holder cell has some element which is interfering with the light path. On the internet, there are all sorts of reviews - this is the bestest to the worst thing ever happened. Anyway, that aperture mask worked and improved things a lot. I have been using the scope with the aperture mask for the last two years. I had installed an EAF after couple of months and things have been satisfactory. Yeah, it's satisfactory. Askar PHQ series is something you should also include in your budget. Don't fret over f numbers.
As far as the mount is concerned, the models being suggested here are all good; you need to make a decision on one depending on your conditions. Zwo mount would make you go in their ecosystem, even if you dont want to. Eventually.
 Z73 progress over the years in pictures:
This was the first light: https://app.astrobin.com/i/7y7sp1
The Bad stars: https://app.astrobin.com/i/qz07iv?r=B
Things got better:https://app.astrobin.com/i/yw0yz5
Things now
https://app.astrobin.com/i/ixecrw
​​​​​​​https://app.astrobin.com/i/c44m0x
​​​​​​​https://app.astrobin.com/i/36303b?r=0
Day before yesterday, I sold the Z73 and am going for a bigger aperture.
SonnyE avatar
It’s hard when starting out because it takes such a large outlay to get equipment. Sure was for me. I spent 5 months researching and building “Wish Lists” of combinations (13+ years ago).
Many mistakes were made because I bought low. Many failures of low-cost equipment then. But I didn’t know if I would continue with my Astrophotography back then. But I’m as hooked on this stuff as most can be and grew over the years.
You have much better choices now. As has been said, the mount is the most important part. A great mount will carry anything you can put on it. So, future-proof yourself when shopping for your mount,
Telescopes may come and go. Not for me so much. In my 13+ years I’ve had >2<. And 80mm EDT I used for most of my learning curve of ~10 years, then I got my present 130mm. But when my first mount died for its 3rd time in 3 ½ years I was done with it. Now I have my second mount and I consider it my lifetime mount.
This mount is rated for up to 50 pounds of Photographic equipment. I have 36 pounds on it. So when I bought it, although using my 80mm telescope the capacity future-proofed me for my bigger telescope.
So do try and plan ahead on your equipment considerations. Choices now may be benefits later. And you have some very appealing choices available.
Clayton Ostler avatar
I started with a 71mm refractor and the equivalent to the 585mc sensor size. I was disappointed that I couldn't get many galaxies close enough but I also couldn't fit many popular nebula in the frame. I ended up selling the 71mm and going with something shorter.
My advise. Get the redcat 51. When paired with the 585 you get a really nice field of view and the pixel size is a great match.
Lots of great targets fit this setup.
That wider fov will be more forgiving on guiding and in my experience will get used more because its so easy to move around and setup.
Omegon 150/750 eq-3
Hello everyone, I have this Newtonian Reflector telescope and I am willing to start taking planetary images and maybe some deep sky objects, what accessories do you suggest I buy? Do you suggest buying a tracking motor?
DSO astrophotography rig building with scope selection and accessories.
Nov 30, 2023
Fornax LighTrack II setup advice
Hello all, I bought a Fornax LighTrack II used for about 370€. It's just the tracking arm so that gave me room to improvise how I would like to have my rig set up and I've come to this final configuration. However, I am very open to any suggestions. ...
Tracking equipment advice relevant to DSO astrophotography rig setup.
Jan 10, 2026
Seeking advice on next steps in my astrophotography journey
I’d really appreciate your views on the next steps on my Astrophotography journey. Having been doing this amazing and absorbing hobby now for just under two years, I know that my journey has progressed from bafflement with how to use the equipment an...
Direct match—seeking advice on next steps in astrophotography journey.
Feb 5, 2026
